Is it possible to tighten ETA 2824 style cannon pinion?
Maybe you got a badly wired one like the one I had. Can you feel the metal object vibrating when you press the red button? -
UK is 240 volt H, but i could plug into a dual volt shaver socket for a 110v comparison, i also have a variable voltage supply control. Thats prob why you experienced poor performance from your blue one. -
Maybe you had a bad one H, the cheap blue one i use has been fine for nearly 3 years now. It demags enough to stop the tiniest of screws sticking to the carbon steel tweezers i use. If it were to fail at some point in the future i very probably would go up a level of device just because.
