Girard Perregaux High Frequency (As1920) Completed
Hi guys, just wanted to share my latest completed project. TBH I'm extremely proud of the results, as its the first watch I've done without any instructional videos or manuals etc.
I purchased the Watch for £50 off ebay as a non runner, partially due to the price & I've developed a liking of 36000 vph movements. When it arrived I immediately noticed the glass was cracked, dial had dirt spots & crown was stuck in the setting position. The case wasn't in particular good shape either. c3939888700c236a7554df8e97ec7d79.jpgafter doing abit of research on dial cleaning, ordering a new glass & a new mainspring I felt ready to take the plunge.
Firstly I removed the movement & cracked glass. 756cfa2d2cae27d9367cd0952e8aa638.jpgOnce out, I could see someone had sprayed the the whole movement with oil or something,it was dripping with the stuff. f3a543ec6bba6264f362e2d6d8ff59e9.jpgI removed the dial & placed it in a shot glass full of l&r extra fine watch cleaner. Left it for 10mins whilst dabbing the dirt spots & diamonds with an ear buddy, after a few more swills round I removed it & placed in watch rinse for a further 10 mins whilst doing shaking motion to adgetate any remaining dirt & finally a good rinse under the tap. A quick blast with the air gun & dial complete. Next, was the case. 1dff53e5be1f840d3540e7123417ea3d.jpgluckily it was a gold filled job, so a quick buff on the machine & a bit if autosol to finish. The case came up like new(well alot better anyway).
Next the movement. Complete disassemble & clean. 3bc539592abe24db9e91cefc53bac012.jpg16e87c4e3f6e09faa3bd1a4af63d2f44.jpgde2f87d33e463bbf496127bcd9960d20.jpg5889a1cecc62bf744faf471472f25497.jpgbd67636c6ddb0148cafbd59c0ec98627.jpg537a96f6fc43a81a1ec4732e1aca5523.jpg1751eae311dd7bcb154d620d6b49ce04.jpg3b170d5def14a7855cd2a3263579b786.jpg37f331cfdbd32dd94a2754964e3ad1e2.jpgfae0111d7ce0faf654bb48be9bc4a053.jpg5cacd68165e595ae4cb5291c08ffbc31.jpgb3324fe66a065e2e18bcacdd00cac05e.jpg353660d5d9051527b7ef533cdd5b7f51.jpg24e20ff20fac01bf85cb759f2cc349f2.jpgfinally the rebuild. This was quite a challenge as I didn't really have a starting point. I started with the mainspring & train bridge. It was after about an hour in I realised I should of started with the keyless as the screw that holds the stem in place is located slightly under the train bridge. However, it's a learning curve. After assembly, I put it on the timegraph, managed to get it in beat & regulated perfectly. Slight concern with the amplitude as I thought it would be higher933a9f169209ff3df1c4e8e59121d1ae.jpg however I proudly present my finished watch 170248579885447f28e2f62177cf4cd7.jpghttp://images.tapatalk-cdn.com/15/08/16/1b5d26f16bc7d24daa11add604ad8119.jpghttp://images.tapatalk-cdn.com/15/08/16/dc1353432ea983734fb9157a0342e27e.jpg
http://images.tapatalk-cdn.com/15/08/16/1242ae43d68b10979b6e53883a7ac9dd.jpghttp://images.tapatalk-cdn.com/15/08/16/e2c4cbdd7167588163004835a31481a6.jpg
Your thoughts would be very welcome.
Sent from my GT-I9505 using Tapatalk
Edited by DJT2
Cracking job, you should be well pleased. You've ended up with something a bit special for no money!
High praise indeed, Thanks Geo.
I only have one question. The day jumper spring! 3fccc12c8c0b574b6964d828f746d635.jpgshould the screw holding it in place be tight? I've just noticed while changing the date that the day wheel moves intermittently. I tried it tight & the day wheel wouldn't seat properly, so slackened it off & wheel seemed OK. Now after playing with it the date changes great & crisp, but the day seems like something is not right.
Thanks again guys for your kind words of encouragement. I can't believe I've just learnt something new which was puzzling me. The Crown would not go all the way in (stuck out maybe 2mm) I assumed that the previous owner had changed the stem & that's were his problems had started. However, this ties in with my day change issue. The Crown sticking out acts as a push button for quickset date feature. Thankgod I didn't chop the stem, that was going to be my next job lol [emoji1]
Great job done,nice watch. As a matter of interest as it has an unusual quick date setting function ie the crown is a bit proud has the crown stem got a seal to keep it water resistant.
Thanks for the compliment & I must admit, I've started to wonder about this myself. It may account for the movement being soaked with what I assumed was lubricant. But no I didn't see any seal on the case, stem or crown. Also, there was no gasket on the caseback.
Found this PDF if it helps however no mention of seals etc.
AS 1920.pdf.pdf
Thanks for taking the time to look, I'd already downloaded that from cousins & your right. No mention of seals. I'm going to have a look at the stem this weekend to see if it's obvious that there should be a seal.
attachicon.gifAS 1920.pdf.pdf
Very nice watch !!! You did quite an amazing job ! Enjoy it (or put at least $500 in your pocket ;) ) !
Thankyou Frenchie, I've decided to keep it, as it has now become the first of what I hope to be many of my 36000 vph fetish.
Excellent work! I hope to be that proficient one day!
Nice!
Your too kind Gary. I think I was lucky getting a good example to begin with. OK it was a none runner, but it was just the hack/keyless. I started at 10am & finished at 8pm lol. Not exactly a fast worker
