Seiko 5 7009A movement runs like a rocket.
John, I believe that @zygo has checked the beat rate with timegrapher and has adjusted to exactly 18000, but still the clock goes faster. @zygo, please count the teeth of the wheels and pinions in the train. But the most pobable answer here is: 18000 X 24 / 25 = 17280, which is another well used in various movements beat rate. May be somebody replaced the hairspring and vibrated it for 18000 and wasn't clever enough to count the teeth... -
You are too far away. If can't find somebody to do the job closer and for reasonable price, then post the wheel and the bridge to me and I will do it. -
I get that Tom but their only use is going to be in the event of a forum loss. Other than that a facebook group that can be set aside in case its ever needed. -
What about th What about the use of email addresses that are not connected to real selves.
