Introducing myself
Hi everyone!  After watching some inspiring videos on YT I got the urge to try servicing a pocket watch. More videos led to learning an ETA 6497 movement … and then to a Smiths mantle clock. I don’t have the knowledge or confidence to do all that is required … but I think I’m making progress.
I’ve been asked to look at my father in law’s Westminster chime mantle clock … it hasn’t been run for decades … and I have some questions, so I finally joined the forum here.
Not sure I’ll be able to offer any help to anyone, but I might be able to offer an insight from the absolute beginner perspective.
Looking forward to contacting with other members. Cheers!
Hi and welcome to the site.  Westminsters are not the best clocks to start on they are quite compljex.  Bes start with a single train  clock to get the feel of then then somthing.like a smiths two train striking clock, get some good books, Laurie Pennmans.  Clock repairers manual, , books by Mike watters,  Donald De Carle there are many on Amazon.
You will Martyn, there will always be someone that knows less than you do and always someone that knows more than you do. Welcome to the worlds best watch forum 🙂
Hi Martin.  You can contribute on anything ask questions on anything we are here to help you over the hurdles, a word of encouragement from you may help another who is starting out as well so feel free to have a go    What’s your location. Uk, USA, Europe?
Hi there  … I’m in Suffolk in the UK. Thanks for saying ‘Hello’ !
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
