Greetings From Indiana!
mike
Hello one and all! My name is Mike and I am a past "lurker" to this site and thought it was time to officially join. I am very new to the watch repair scene but totally fascinated and curious with the horological world. So thank you in advance for the advice and remember, "keep 'em tickin!!"
Welcome Mike all levels of horology can be found here enjoy the forum.
    • Looks lint the teeth on the hour wheel aren't meshing with the teeth on the calendar intermediate wheel, maybe the hour wheel is sitting on top of this instead of meshing?
    • If the oil drop was freely standing on an epilame treated cap jewel it could easily slide off if you knocked the watch hard but the balance pivot keeps it in place.
