Strange Jewel Gauge
52 minutes ago, jdrichard said:
Just bought this tool and am wondering how to use it. Says it’s a Elgin National Jewel Pin Gauge…but not sure how it would be used to measure the jewel diameters or the hole size.
Can you give an idea of scale please JD.  I wondering if this is only part of the gauge.
Maybe it should come with a tapered pin. The jewel hole is slid down the pin until it comes to a stop, then placed beside the rule to get the corresponding hole size.
If that's the case, then JD, will have to turn a wire to the correct taper in order to use the gauge.
Is the graduated part of the gauge tapered?
I'm wondering if you slide it between the fork horns of your pallet fork (with safety pin removed) to measure the gap and determine what size impulse jewel (or pin) you should use.
you wouldn't want to do that it's a pain to put those back where you found them.
Then the annoyance is I've seen the tool before and I see how it's used just can't quite remember and definitely don't remember where I saw it being used
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
