Greeting...my First Post
Yttrium
Hello Everyone,
I am new here. I hope to learn and pick up some knowledge about watch repair from the experts here.
Firstly, I would like to say that I really enjoy watching Mark video and I learn quite a lot. Thank you, Mark, for the video.
I taken a interest in watch repair a few years ago and did a few overhaul with my own watches. I must say it's really encouraging when you see your 10 years old watches "beating" accurately again after it's being overhauled but sometimes things don't really go well. Patience is the key here.
Talking about problem...I have a few questions about my 3 weeks old watch when it is put on the Timegrapher.
When Dial Up, the display is all over the place but Dial down seems ok (almost straight line). Please see the attached files. I remember the first day when I have it, I put it on the timegrapher and the dial up reading does not seems that bad but not as good as dial down. Having said that, the watch loses about 3s/d when not worn for one day placed dial up, after resetting, it runs about +/- 1s/d when worn everyday.
Can anyone share some light here? I opened it up and did some minor adjustment to the beat error and rate but to no avail. Could the hairspring be out of true/round or problem with the balance pivot? I am curious and need to ascertain what's wrong before opening it up again.
Best Regards
Daniel
post-1314-0-86214000-1438097170_thumb.jp
post-1314-0-15426000-1438097174_thumb.jp
Hi Daniel, whenever I see a positional issue like this, as a starting point, I evaluate if all is well with the balance. How old is the oil? You say it is three weeks old...was it already second hand? If you have the means, may i suggest you remove the balance, inspect the pivots and jewels and re-oil and see if that works. As the problem seems to occur dial up, then perhaps only look at the end on the cock/bridge for starters.
Also welcome aboard.
Regards
Regards
Hi Hamish,
The watch is brand new. I will inspect/clean the balance pivot/jewel and re-oil and see how it goes.
Thanks!
Welcome to the forum Yttrium.
Following on from Will and Hamish, I would suggest you oil the pallets and the escape wheel, but not the pallet fork pinions, and see how the graph looks. I'm suggesting this because you have two distinct lines of snow on your Timegrapher. Instead of getting a dampened tick, you may be getting an undamped ting or microscopic bounce between the pallet and escape wheel. Please read up on this process before going ahead, because you need very little lubrication on these components. Too much oil and it will be detrimental to the running of the watch.
If oiling doesn't work, you may well have a distorted hairspring that needs attention, although I wouldn't have expected to se two distinct lines of snow, but more of a general blizzard! i would not recommend that you interfere with the hairspring, it takes a lot of skill and experience to assess and work on hairsprings.
Following the advice from Will/Hamish/Geo......Thank you!
I inspected the balance pivot with a 10X loupe, seems OK (at least as far as my eye can tell). I checked the oil on the balance cap jewel....hmm....the oil is centered around the jewel but it seems to cover more than 3/4 of the jewel....too much oil? So I remove the balance jewel and cap jewel and cleaned with lighter fluid, use the smallest oiler that I have and applied Moebius 9010, just a small dot on the center of the cap jewel. I hate to do this because it is so difficult to put back the cap jewel without "disturbing" the oil....it take me 3 times to do it properly because once I dropped the cap jewel I have to clean it and oil it again!!! After installing the shock absorber, I examined the oil spread again, this time it only covered about 1/2 the cap jewel. So off it goes on the Timegrapher. The result looks better than previous but still not perfect. I removed the balance and check the hairspring flatness, with the balance wheel on top (Dial up position), I noticed that the hairspring is slightly slanting downwards. I am not sure if it is the cause of this imperfection. I might try adjusting the stub height first before "touching" the hairspring (every time I "touch" the hairspring, I almost always mess it up).
That's all for today...
post-1314-0-07432100-1438269092_thumb.jp
Did you oil the pallets?
I'm also going to say that although the graph is not perfect, in real terms your watch is keeping pretty good time. I personally would leave it just now and wear it for a while, it may just settle down. If the watch was not keeping time at all well, then delve deeper, but it would be a shame to risk making things an awful lot worse by tinkering with the hairspring.
Wait....hold on....after running the watch for about one hour......the graph improves....I think it takes some times for the oil to break-in or am I missing something here?
What's going on? At first I though my Timegrapher might not be working properly....
Is it really due to too much oil on the cap jewel? How can a experience watch company (I won't state the brand here) not know how much to oil? Weird. But hopefully I don't have to touch the hairspring. I will wear the watch for a few days and observe again.
post-1314-0-51910700-1438270603_thumb.jp
Hi Geo,
No, I did not oil the pallet. I start with the balance first.
The amplitude also reduced from 317 degree previously to 270 degree which I think 270 is normal for this brand, from my limited experience with several watches of the same brand. Oh well, we will see how it goes when it's on the wrist.
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
