Help Identifying This Vintage Watch
Hello,
Hoping to get some help identifying this watch. This was my wife's grandmother's watch, which most likely she received from someone as a gift (she was a gynecologist and people tend to get really excited about giving birth and want to present their delivering doctor with all sorts of gifts). It was in a pretty bad shape and not running. The face of it is pretty scratched up and I can't make out the name of the brand. I can possible make out something like "CRE 17 Rubis" on it. The bridge inside says "Swiss Made 17 jewels".
I am hoping to try to restore it as I didn't notice anything wrong with except it was pretty dirty. So hopefully, it just needs some cleaning and lubrication. This is my first restore/repair job, so wish me good luck 🙂
image.thumb.png.d8b0331e898ee9f6332970267541dcd1.pngimage.thumb.png.06928f445f5356a9c14b8ef46910cab2.pngimage.thumb.png.1377a81671a7ea44e308515e6c53f1eb.pngimage.thumb.png.74803ad3762f1d41dcca3587a5a7f1ee.png
28 minutes ago, 0812 said:
Thank you. I did take a bunch of pics in the process of disassembly. So here are a few. I didn't see any other inscriptions anywhere else except "AV41".  Thank you!
image.thumb.png.514baab721abfd4ad99f9a3d4570ef5c.png image.thumb.png.2fa86e711c36f2eeb9eb26475cb6745d.pngimage.thumb.png.e20543840453f36a98ac0cdf235d8b9c.pngimage.thumb.png.ee8c3a1f3f37ea78932572a8c9d6935c.pngimage.thumb.png.b9825dccdb4bcee4b580698821c7a5b2.pngimage.thumb.png.dcb04ae09ada3bf366b0a00164680f69.pngimage.thumb.png.0821700c7ac417639239b468e2e25213.pngimage.thumb.png.c9b91f72a9136c8f06883e5e8f5a5402.png
Don't know the movement but the trademark is.
The check spring has snapped off.
Wow, thank you. You guys are good!
So do you suggest I change the mainspring? Is this what you mean by "Cousins"?
https://www.cousinsuk.com/search?searchTerm=GR4077
Also, "The setting lever spring on the set bridge (part #445) is broken" - which of my pictures do you see it on?
Sorry for the noob questions, I am new to this. And thanks a lot!
That's the spring you need, but you will be able to buy one in the US.
The set spring is the part arrowed below. You can see yours has broken off at the arrow.
oh wow, I see. Thank you. How would I go about looking for it? Should I look for Aurore Villeret setting lever spring on the set bridge part #445 ?
41 minutes ago, RichardHarris123 said:
Can you make out what it says on the dial?  Please post photos when the dial is cleaned and let us know how your progress.
I can't unfortunately. Any recommendations on how to clean it? It looks like someone tried to scratch off a layer off of it, thinking that it's dirt or rust. Very unfortunate. I used an ultrasonic cleaner and a swab with alcohol to clean it, but definitely needs more work.
25 minutes ago, RichardHarris123 said:
Not sure there's anything more you can do.  I think it says Acre 17 rubis.
These are meant to be good. Can buy cheaper options. Won't remove the scratches.
Thanks. From what I understand Ancre 17 Rubis is a generic term for "With 17 rubies". So no brand name on the dial as far as I can see.
  • 4 weeks later...
Guys, I am starting to reassemble this watch back together after receiving some of the parts that were broken. I came across this part that fell out during the the disassembly and i didn't capture where it belonged. Any ideas? image.thumb.png.17a2f601459e995ab6977e4067b12826.png
13 hours ago, Klassiker said:
That's the setting lever. It goes on the dial side and is part of the keyless works. It is held in place by a long screw with a short thread, which is fitted from the movement side.
Thank you. can you tell me where on this picture would it sit? image.thumb.png.90691a252cd9f162d125cef62e8158b1.png
  • 3 months later...
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
