A friend gave me a 2012 Citizen Model B740 Promaster dive watch which doesn't run and has a broken stem (part no. 069-9930), so I decided to try and fix it.  I don't remember ever fixing a watch like this or any watch but for some reason I had a set of tools.
I opened the watch up and removed the capacitor.  The voltage on the capacitor was 1.2 V instead of 1.5V.
With some help from a local watchmaker, I removed the broken stem.   I now have the crown, the stem and a small section of either a threaded rod or a stiff spring.   I checked with Citizen USA and the stem is no longer available (at least in the US).  So I have a couple of questions:
Is the capacitor dead?   Can I recharge it?    I can buy a replacement for about $20.
Is the anywhere in the world where I might be able to get a replacement stem?
Is there any way to repair the stem?  I doubt that would be easy.  How do they make these stems in the first place?
Online I see stems for sale that look similar to 069-9930 and are also 21mm long and start with part no. 065-xxxx.   Is there any chance that one of these stems would work or at least would get the watch running?  I obviously don't care if the watch ever sees the ocean again.
When do watchmakers and amateur watchmakers throw in the towel?
Thanks
Barry
If there is still some thread (a couple of mm) on the part of the stem that goes into the watch then you could use a stem extender, which does exactly what its name suggests.
https://www.cousinsuk.com/category/stem-extensions
You will have to either get a new crown or recover the original, and you will need to cut the extended stem to length.
Professionals, usually when it becomes uneconomical to proceed unless they have some other motivation to keep going.
Amateurs, it depends on the severity of their affliction but at its worst, never..... and it's incredibly infuriating!!!!!!  🤣🤣🤣
Eco drive watches do not use a true capacitor anymore. The "capacitor" is actually a rechargeable battery. If the old battery still reads 1.2V, then there is hope that it's still ok.
The next question is whether the photocell is working? Can the watch charge up the battery?
Then the next question is whether the movement is functioning properly?
The winding stem is not a big problem. A competent watchmaker should be able to fabricate one easily.
Did you try to let the watch charge its battery?   Solar cells wont last for ever, you might find the watch fail  to charge the new battery.
You should investigate if a stem extender wont catch onto any part, such as  movement itself, stem tube, ring etc.
Rgds
Hi I have attached the tech sheet for the citizen B740  It contains a lot of useful information . The solar cell takes upto 4 hrs to charge.  I usually leave them on a sunny windowsill and thatb works ok but if the cell its self is duff then any amount of light will breathe life into it.
B740.pdf
Wow - I was pleasantly surprised at the quality and quantity of the responses to my post.    I will try some of these suggestions.  I have attached photos of the crown and stem as I found them.  Would a stem extender work?
I am going to try to charge the battery/capacitor back to 1.5 volts, and I will report back
Thanks to all.
The photos are a bit blurry but does the end of the stem have a threaded hole?
I've never seen a stem like that. If indeed it has a threaded hole, does that short bit of stem screw back into the hole?
Thanks to all.
As best I can tell with a magnifying glass there are no threads in the hole.   (I may take a look with a microscope if I can find it).   I tried to screw in the short piece of stem without any success.   I was thinking, I could solder the short-threaded piece into the hole, but that probably would not work.  There must be something missing but it looked like everything I had added up to 21mm which seemed to be close to the correct length.
I also cannot figure out how a stem extender (an earlier suggestion) might work, but I might order some and give it a try.   It is clear that none of this makes economic sense, but that is why this is a hobby.
I was also looking a some replacement Citizen stems (not meant for diver watches) which looked similar and were also about 21 mm in length.  I just want to see if I can get the watch running, and if I can I can set the time once (twice)  a day with the battery.
Do these batteries have an extra tab on them to make better contact?
Thanks
Barry
I noticed that there is an o-ring on the stem.  Is it possible that the two parts of the stem on either side of the o-ring can be unscrewed or is there just an indentation in the stem to fit the o-ring?
 In case you can't find a new stem to buy, you can solder a piece ( all thread ) of another ( broken stem ) into the hole of this one and  make a long stem. The problem you might have is the two pieces soldered together might not make a streight stem, in which case melt and try again .
Good luck pal.
Hi Barry the O ring on the stem is for waterproofing ,  You can use a 1,55v cell in the watch to checkout its functions but obviously wont charge up but it will provide the voltage to drive the watch.  The stem according to the tech sheet attached to your previous answer designates it as a one piece construction,
I found a stem which will at least adjusts the time and I have ordered a new battery/capacitor.  So I will reassemble and see if it runs and charges.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
