c1970 Smiths (EB8800)
GDub
Hi Guys,
               Just a quick shout out for advice/suggestions, I am very much a newby to watch making and currently completing Marks Level 3 training course, this said, I confidently acquired a vintage Smiths mechanical wind watch, I performed a full strip down, clean and lubrication re-build, new crystal mainspring case polish etc. all sounds good up to now, however, I now find that the watch is erratic on the timegrapher, one minute 20-30 s/d and 1.5 beat error, as soon as you change the crown orientation if goes crazy 100-300 s/d, 9ms beat error, this said, I checked all installed components as free and located correctly and not over lubricated, all seemed OK, but decided to strip it down again to double check (all was good), without the pallet and balance in the watch felt very smooth on turning the crown so the only question is the balance and hairspring at fault? Is it possible for the balance/hairspring to cause these issues? One thing I did notice is that the hair spring seemed a little slower that all my other I initially put this down to it coming up on the timegrapher as a 1800 bph (all my other watches are 21000 or above), also the watch has a tendency to stop but starts again with a little tilt side to side.
Any thoughts guys? Thanks GDub.
    18000 bph is correct.
 Sticky  hairspring due to contamination or magnetisation, sometimes intermittently which is hard to spot with naked eye, making  a vid of oscilator running helps to spot hairspring issues.
  • 10 months later...
Do you mean ,  when you turn the crown to advance the hands  ?
Is it pin pallet ? did you oil the escape teeth.
Edited by Nucejoe
    • @JohnR725 has pointed out many times that the Swiss don't care about amplitude, the timekeeping is the most important.  Give yourself a  pat on the back, great beat error and timekeeping, nothing to be disappointed about.
    • I'm bothered but I agree he's a busy man and I don't want to bother him.  In the meantime, we really do need to have other ways of contacting each other
    • This is as complicated as epilame, too many unknowns. The life expectancy in the UK is circa 80, so most people from 1944 or earlier are dead.  Assume they had children at circa 20, they died in 2004. Their children started selling 1944 watches in 2004, so pre-1944 watches must be getting more rare.   It doesn't work though because as you stated some were sold as tat, but since watch prices have increased people have decided to sell when they may not of done in the past.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
