1956 Bulova President 10BU movement work in progress
Just got this lovely little lad. Only just started researching, but thanks to @GuyMontag's suggestion, it appears to be a President. This thread at MyBulova backs that up.
Edit: also this thread at MyBulova that Guy linked, describing the "President P" variant. I haven't been able to find any other pictures or advertisements or mentions of the charcoal dial on the internet, but my Google-fu may not be strong enough.
It came to me fully wound and not running. Found some corrosion by the stem and on the crown wheel, so we'll have to see what's deeper inside.
Giving the balance a little push, it seems to want to run, but it feels gummy. The last Bulova movement I worked on had the lubricant in the jewels turn rock hard, and it felt exactly like this, so I'm hoping a good cleaning and service will fix it.
The face is in pretty rough shape around the diamonds, and I think I spy a fingerprint or two.
Anyway, I'll keep y'all updated of my progress as I go!
Edited by ManSkirtBrew
added link
You have an import code there msb, is it axo ?
Corrosion doesn't seem too extensive. Other than the outer half of the stem, the keyless works look pretty good. There's some on the center wheel arbor, which may need replacing.
Someone scratched "8020" into the back of the dial.
Lots of side shake in the barrel bridge. Going to have to close that hole up. Definitely going to need a mainspring.
Overall though, could be worse. I don't see any cracked jewels or anything alarming. Yet.
  • 3 months later...
Finally got back to work on this one, and boy did it clean up nicely. Only part replaced was the mainspring. It could probably use a new stem, and I lost the little spring on the stem during cleaning, but otherwise just cleaned and lubricated.
I polished the crystal with red rouge, then automotive plastic polish, and the results are nothing short of stunning. Despite the dial being a disaster up close, it really looks great on the wrist.
20230425_223111.thumb.jpg.e17542d802f8051e0284481e17a2ca61.jpg20230425_223137.thumb.jpg.269ee5df56e226b98d7144140b2e5134.jpg20230425_223126.thumb.jpg.83c6c3d639121977beee1b8010d6495f.jpg
  • 2 months later...
Sorry to revive this old thread, but I could use some help.
I noticed today that the movement is loose in the case--when I wind or set the time, it wiggles the whole movement.
I'm not super experienced with front loaders. Is the friction between the dial and bezel what's supposed to hold it in place? It doesn't seem like there's enough here.
The movement ring on the back is free to spin in the case back, but it seems trapped in place (I haven't tried to force it out).
Edit: my other thought is looking at this lip on the movement ring. Is it possible the ring is supposed to go between the dial and movement? I'm still not sure how that would hold the movement in place, though.
Oh wait, I just remembered something. There was a spring on the stem when I got it that somehow evaporated during cleaning. Could that be what keeps the movement centered? Seems weird, but I guess anything is possible.
If so, where does one find such a tiny replacement spring?
11 hours ago, RichardHarris123 said:
I don't know but a while back we had a misunderstanding about front loaders.  To me the back is removable but the movement comes out of the front, to you the back isn't removable. Does anyone know the answer or is it a mute point
Looks like a one-piece case to me (monocoque).  Perhaps there was a reflector ring that interfaced to the bezel to hold the movement in place.  I cannot find this case in the Bullova Case Parts Catalog.  I do not see a movement number stamped on the inside where I would expect it.  If there is a number (not visible from the pictures) post that number.
This watch has a 1956 date on the caseback which is before Bulova started using case numbers so it won't be in the case parts catalog. I don't have this watch but I have a handful that are somewhat similar.
None of them have a moveable ring like on yours. When the movements are in the case they are somewhat difficult to get out, I have to pry them up to get them to pop out.
That definitely does not describe mine. It just falls right out the front.
If I get some time tonight I'll pop off the dial and see what I can discover. Thanks for the info!
I do not know the official meaning of "front loader" but when I use the term, I mean that there is no back that can be removed.  Many pocket watches come out the front even though the back can be opened or removed.
Please, no offense, but it is "moot" and not "mute."  A common error.
You are correct and something I  once knew.  No offence at  all.
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
