Timegrapher reads slow, watch runs very fast?
It seems this topic is becoming very interesting 😀. Here are two more pictures that might help to identify the movement. The diameter of the dial side is 40mm, and the other side 36,5mm.
I'm with @nevenbekriev Rich, it just looks a normal movement to me .... unless you know differently. Do you have pics of yours? Who is the manufacturer?
Rich, this one seems rather regular movement to me. Yes, what You describe exists, but I doubt that the one on the picture is something similar. -
@Neverenoughwatches Many thanks for your remarks. As I wrote earlier, I was a bit reluctant to disassemble this movement, and you gave me further motives to be careful. I'll just remove it from its case so as to clean it a little.
I am not sure for the terms in english, but if I directly translate from Bulgarian or Russian, there are 'magnetic soft' and 'magnetic hard' magnetic materials. The first group will not get magnetised, thow they will be attracted by magnets. The soft iron for example. The second group, like hardened steel, will get magnetised. So non magnetic hairspring aloys belong to the first group.
