Hello, I’m new here
Bill241
Hi,
Many thanks for letting me join. I’ve only recently started getting into horology as a serious hobby- I was given a copy of George Daniels’ grand tome (Watchmaking) last Christmas- then decided understanding the workings of a watch was more interesting than just owning it.
Having spent months learning, via books, the BHI course and Mark’s online lessons, then practising, succeeding (and failing!) I hope I’m now in a position to be able to contribute something to the forum. And plus, every day is a school day…
Bill
On 11/28/2022 at 12:06 PM, Bill241 said:
Hi,
Bill
Been a while since i welcomed anyone, so here i am, and there you are Bill "welcome".  Congratulations mate, a great hobby to have, both very rewarding and frustrating often within minutes of each other. Any help you require, your first port of call is to identify the movement to let everyone know what you/we are dealing with. Secondly some good clear detailed photos so everyone can SEE what you/we are dealing with. By now you will have some fair knowledge as to what to look for and where to look when ID ing the movement,  a movement size is helpful also when searching through the bestfit books to match up the keyless works of a known maker. Pickies of timegrapher traces and readings come in very handy when fault finding, so if you have one then the up/down  readings for a start and the verticals are great especially for the pros that are 👍at diagnostics. Enjoy the experience and massive learning curve that is coming your way 🙂.
Rich.
    • Welcome to the forum, enjoy. I have a varimatic that went  out of sequence because it’s hydronic oil ran very low. Must admit it’s still in my garage just know time to fix it. Purchased a cheap Indian Junta/ sonic Pearl as a stop gap a few years ago and it still performs perfectly so no incentive to fix the Varimatic.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Recently purchased a L&R Varimatic knowing that the piston does not fully rise in the cylinder. The likely cause is air in the system. The manual calls for using a bleeder cup, which is as rare as hen's teeth.Does anyone have any experience with this issue and if so, how did they resolve it?
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
