Hello together
I would like to introduce myself briefly. My name is Jonny and I am from Switzerland. Since childhood I am fascinated how a mechanical watch works. Now I am a bit older and have the patience and the skills to dive into this fascinating world. Unfortunately, there are no in-depth workshops near here and I would like to buy this online course from Mark Lovick. However, I am mainly interested in automatic movements and the course is only about manual winding movements. Should I still buy the course? I want to disassemble and reassemble an ETA 2824 movement. I work in the engineering industry and in my spare time I assemble micro drones. A steady hand and good eyes I have already as a prerequisite :-.)
Do you have any tips?
Thanks in advance
8 hours ago, manjo said:
Switzerland.
So you're from Switzerland where you currently located?
You're probably aware that when you start off in any field like the engineering field you don't just start at the top you start at the bottom and get the basic theories down as you work your way up.
So for instance an automatic watch is the manual watch with an automatic attached to it. Sometimes its integrated in all is one thing but a lot of times it's a separate attachment. So everything in Mark's course on mechanical watches still applies to the automatic watch. It just that you have to start somewhere and it's easier to start with the basic mechanical watch not having all the complications of the automatic watch.
Im from Zürich...
Thank you John. Thats true what your saying. I will try to get a basic movement and start with them.
Hello and welcome to the forum.  As mentioned by John,   Start with the basics and avoid any unesscesary complications in the first instance  and once you fully understand the basics its then time to move on,
witschi_training_course.pdf TZIllustratedGlossary.pdf
    • Hi, I just wanted to share the unmistakable quality of a Rolex made in approx. 1990. Cleaned and serviced for a friend using appropriate oils and greases, with Epilame on the parts recommended by Rolex. New mainspring and upper setting and jewel for the minute Pinion (cracked jewel). Run in overnight and then worn on the wrist for a couple of hours to warm. Without any adjustment to the balance weights the watch ran at 0 SPD DU, all positions within +3 and -2. Vertical amplitude after 24 hours of 230 degrees minimum. Watch running at zero seconds per day on wrist when worn 24 hours. Serviced just once before 20 years ago. No need to buy the Microstella regulator tool, not this time anyway 🙂 No scratches or damage caused to screw heads and bridges. All seals replaced and waterproof tested to 60 metres. All good practice for when the time comes to service my own Grand Seiko.
    • My kid woke me up at 2:00 a.m. I couldn't get back to sleep so I decided to go to the workbench. I was to tired to work on a watch so I decided to dress up tweezers and screwdrivers while having a drink and listening to some music.     Luckily I got a comforting nap after lunch and started working on this beautiful Raketa Big Zero.
    • Good shout - I'll grab something like that and some around the required size from cousins too...
    • Hi, I have a lot of experience with Seiko and you can make all of those run within a few seconds a day with small adjustments to the Etachron regulator. You just need a timegrapher, an Etachron adjusting tool and ideally a stereo microscope, along with a bit of knowledge and patience. Not difficult at all for a watchmaker professional or a hobbyist like myself.
    • Courtesy of my parents who are at the Henry Ford Museum (formerly Greenfield Village) in Dearborn, Michigan today - a photo of the watchmaker's bench setup in Thomas Edison's Menlo Park laboratory. This is a pretty good display, a pallet warmer, truing caliper, staking set (unfortunately closed box), spirit lamp, and check out that six jaw chuck on the lathe. The museum is a mostly an outdoor village where Ford had moved numerous buildings important to himself and to the history of technology in the USA. (Also includes the Wright brothers' bicycle shop for example). As a teenager I worked in an 1850's tavern there. There are several other large lathes too.
