Hi all,
Just getting into this hobby and got a loupe with a Bergeon steel handband to hold it. I cannot for the life of me, get this in a comfortable position. Has anyone had this problem too? If so what was your solution? I'm wondering if the specific headband I bought just isn't the right one for me and have to just try another brand.
Anything helps, thanks guys.
The headband can be bent to better fit the individual.
There 2 ways of wearing the headband. The first way is to have the band exit on the same side of the eye and go around the back of the head and the come around to the the front, ending up on the forehead. This method requires more adjustments to get the loupe to fit properly.
The second method is to wind around the head in the other direction. i.e. run across the forehead first, around the back of the head and end up on the temple. This method seems to fit me better.
Try out both methods and see which suits you better.
I know what you mean about the way the wire band can fit. I bought one over 15 years ago and another about 10 years back. The newer one looks identical to the first, but doesn't fit as well. Visually I can't tell any difference between the two.
If you wear glasses of any type, you might consider the loupes that clip on the front of the temple. If you can get them to stay put on the temple, they're as comfortable as wearing your glasses, with the right amount of "boost".  Good luck.
  • 1 year later...
I couldn't get on with a wire either so bought a cheap pair of reading glasses from the chemist, pushed out one of the lenses, drilled a 1" hole in the other and fitted the loupe through the hole. So easy to get on and off.
@watchweasol  Sure no problem. As I said I couldn't get on with the wire holder for the loupe and had no chance of holding in with my face muscles for any length of time (how do they do that??!) so had an idea when I saw a cheap pair of £2 reading glasses in the chemist. I bought a pair and after taping up the lens with masking tape drilled a 25mm hole in the centre, I only had a wood drill bit so went very gently. I think it helped it was blunt or it would have probably broke the lens.  I then ground/filed/sanded out the hole (quite easy as its plastic) until a loupe fitted through (about 27mm for mine). I then removed the other lens . The loupe is removed and changed easily and is comfortable to wear. Hope this helps someone else.👍
Edited by Burruz
HI @watchweasol  Its primitive but I am grateful for your kind comments. If I wore glasses I would probably have got the clip on ones although these may have held the loupe too far from my eye. With my 'creation' I can adjust the depth as well by sliding the loupe further in or out. One thing I forgot to mention was that before I drilled the hole I took a look at myself in the mirror and marked the centre of my eye on the lens as it will probably be off centre. 👍
great simple idea, I love it.  I was battling with optics when I started.  In the end I have a clip on loupe for some work, but recently purchased a stereoscopic microscope from Amscope.  Total gamechanger for me.  I've been straightening out hairsprings ever since 🙂
Edited by MikeEll
Hi Mike
Yeah I think I will have to bite the bullet and spend some money on a microscope even if for inspection purposes only. Just got to figure out how I justify it to the missus!😁
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
