What’s this movement?
Hi if you can down load a copy of the bestfit books, there is an identification section where you can compare the setting lever spring with the pictures.  what size is the watch in mm as that narrows down the search criteria.
There used to be downloadable copies on the site put there by Old Hippy  Search the term  "mediafire" as that was what Old Hippy used to put them on site.
Many thanks!
you see on the dial side there is a number 150? Did notice next to the 150 it looks like a symbol but it also looks like glue on top of the symbol . Usually inside that symbol is a letter but I can't see it because of the picture and almost looks like glue. Then if somebody doesn't give you the secret location of a downloadable copy of the bestfit book I'll look it up for you but I need to know that and it be really nice to have the diameter measured on the dial side
Hi. Thanks guys. Dia 23.68mm. The symbol has been machined out at some time unfortunately. Attached more images of another same movement but this one has even less info engraved on it. Any help appreciated. No luck with best fit download yet.
Ta. B
5 minutes ago, Boydie said:
Dia 23.68mm
I've attached a chart to look up  millimeters size and converted to something useful for the bestfit book.. llooks like 10 1/2l.
aanother way to find it is to go here and search for the number.. Or somewhere on the site  you can enter in size and various specifications and will give you a list but conveniently I don't know where that bookmark is clear on your own the find that.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk
looking in the bestfit book gave me a clue and the website has a picture
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&FHF_150_0
then I'm attaching an image snipped out of the bestfit book.  This is why wanted the size because he can't look at a picture until how big it is and searching through all of these is a pain.  Which is why typically I won't do it unless someone gives enough information..
one of the reasons I'm deliberately not being helpful on this one is I purchased mine. So not sure who actually holds the copyright even though somebody will come along and tell you where to download eventually for free.
watch-ligne-size-chart.pdf
Ta. B
It is possible to pay for a download from the now registered owners, it used to be a tenner. WW helped me find it from old hippy's post, there was a couple of links to go through as i remember and  a password to open it once downloaded. I'm sure i wrote down the post link dates at home somewhere.
The password for the Bestfit books Old Hippy posted was tickandtock.   I have just checked and the references are still there   The search criteria is search everywhere so it loos through the posts for reference.
ie   Search       "mediafire"         verywhere (in the drop down menu)
7 hours ago, Kalanag said:
The bridge design of the FHF 150 is very different though!?
the fingerprint system identifies the watch by the setting components. Ideally you would have the physical bestfit book because the pages are printed to an exact size and the parts will lay on top of the book.
As someone else pointed out the bridge design has nothing to do with who made the watch. Lack should be quite common to have variations in bridge designs.
Then conceivably but I don't feel like looking it up it may be that both watches are actually the same would have to look up how the parts cross reference as to whether they cross reference.
Like for instance if somebody purchases OEM movement and re-brands it as their own and possibly changes stuff or possibly dozens then with the fingerprint system they may appear to be identical.
8 hours ago, Kalanag said:
this is where I purchased mine from which is why won't give you the link to where you can download it for free. It was my understanding that they have the copyright to it.  but it's still out there for free if you know where to look a just my understanding that they have the copyright.
Many thanks!!!
Thanks WW!
Many thanks John. Very useful, all of that info. Different bridge makes a lot of sense. Cheers!
The copyright is with William S Mcaw and available for purchase, copies of the bestfit books turn up on ebay,etsy and the like from time to time but are expensive.    I believe the downloads on the watchguy site are still getable  for free as is the ones Old Hippy put on this site( already mentioned)  the actual books are better as explained by John   but if find the page(s) you want just print them out and keep them handy.
somewhere I thought I read it on his website that he was asked to remove the offending bestfit books because of copyright infringement. But
https://watchguy.co.uk/cgi-bin/files
so at the link above you can see you can download stuff like tech sheets and all sorts of nifty technical documentation like possibly a bestfit book.
scroll down to the miscellaneous technical and then in there is the word bestfit click on that
I always find this website a little strange in that when you click on whatever you want to download you basically go back to the homepage and the download link is at the very top of the page you'll see that it's actually appears to be two separate volumes but there it is and it's free
but there is a problem with the PDFs and that is their PDFs. They're wonderful if you have a general idea what's in there in the witschi looking for but ideally really went the physical blocks also. They want to pick up the physical books  from time to time and found through them because there is so much information here it basically becomes impossible remember everything in their. Job that means everything to pick up the book you'll discover new stuff but it's all very useful and helpful stuff.
then looking at the website where I purchased mine from $10 for something that's worth its weight practically in gold it's well worth it somebody's responsible for scanning it and having scanned documents it's a real pain so somebody did this they should be rewarded.
But here's something you can't download sort of and it's not $10 hits $100 basically that's the online version no pictures no PDFs of the book. But if you want to cross reference parts you can do that.
https://mccawcompany.com/product/bestfit-material-matsys-for-life/
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅 The oil is repelled by every surface of the epilame even that which it sits upon. So the oil pulls together to make as little contact with it as possible, but the oil cant float above that area, it can only sit there on top of it. Under gravity the oil could potentially run away as an oil bead, unless the epilame has an adhesive property which i dont think it does ? So something else keeps it in position ie a pivot under a cap jewel . But that isn't the case in a pallet jewel situation.
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
