Bought this clock at a flea market. Can not find anything about it.
By eccentric59 · Posted
Case in point, I just scored a lot of 4 Timex mechanical watches for $15.50 which puts the individual watches at $3.88 each, or £3.09 (or €3.59, ¥28.08 (CH), ¥607 (JP), ₹324 ... or 0.00006 Bitcoin ) 😉 -
The 73 was my setting lever make Mike, same piece fitted to your 72. I enjoyed working on the movement, fair quality. 73 wasn't front loading,but a tight spacer ring that i had to fit onto the movement before casing up. I had to adjust endshake on the third wheel so apart from the make everthing else was good. -
Well it's arrived, and it's a pleasant surprise. A 11.5''' 21 jewel FHF 72. It's running (just) and looks in great condition. It needs a good service, and new crown and strap. It's a front loader but doesn't have a split stem. There's a small lever (visible when you remover the bezel), which when moved, frees the stem and the movement from the case (a new one on me).
Hi All, I'm Geoff and I've been working on/with watches and clocks since I was thirteen. My dad was a watchmaker and while he did not want me in the field as a profession, I've always maintained a pretty good working knowledge. In the '70's I kinda got pulled back into things because Quartz revolution began and he only had limited electronic knowledge. So we combined skills. He the watchmaker and me the electronics tech. Being here in NY helped because we got to know the folks from Bulova, Seiko, Citizen, and WOSIC. H.B. Freid was my Dad's teacher and I was fortunate enough to get to know him too. I still maintain a bench here at home and occasionally work on watches for friends although the hands aren't what they used to be. Not going to be working on any FHF59 or AS1012's any time soon. Oddly enough though my years working with the field taught me how to work on almost anything else mechanical and mostly electronic. Since I was the one in the family who maintained Dad's cleaning and timing machines. those experiences carried over quite nicely into the worlds of recording and audio as well as others. I look forward to the discussions and maybe still learning a trick or two. Cheers to all and nice to be here.
