Hi, i have got a fusee movement, it has a chime silent facility but i am having trouble working out how it resynchronises itself after it has been put on silent. The only way i am able to do it is to manually set it off at quarter past and run through the chimes one by one until they are back in sequence. Thanks in advance for any help
This is one of those massive clock movements, extremely well made many are English.  Winterhalder & Hofmeier also made many like this but there is a difference. From the photo I would say this is English. The self correct is not working as it should. The best way to find the trouble is to remove the chiming levers and check all parts. Have you had it apart and now it is causing problems? Any signs of wear on the chiming side? if no then you need to build the chime side and watch the way it works. It takes a lot for a movement like this to miss behave. As its out of its case I would give it a good once over of the complete movement. I would like to see the chime side of the movement between plates.
@oldhippy @watchweasol thanks for the replies you are absolutely right this movement is massive and very heavy. I have not taken it apart this is how i got it, the clock looks in pretty good codition and i can't see any excessive wear. i have studied the chiming mechanism and there doesn't seem to be any way of it being able to sychronise itself.  Is it possible that this clock could have been made without that facility. Hope the photos help.
Hi  when you look at the front of the clock the lever at the top right (the one with the hole) when you lift it does it release the rack and cycle the strike.  Its a substantial clock going by the plates and the chime barrel.
If you can get you hands on a copy of  De Carles book  Clock and Watch repairing  Chapter VIII gives a detailed description of the workings and several warnings regarding the power held in the fusee spring  which is enough to break fingers so be very careful I have attached some of the information from the book for you .
Scan.pdf 1.pdf Scan2.pdf
@watchweasol yes the lever you described does exactly what you say, i really appreciate you attaching the pdfs i have read the last paragraph on page 121 this official confirms to me that this movement does not have the capability to syncronise automatically which means the clock is working exactly how it should. Thank you for your time and help it is very much appreciated.
Sorry for my late reply. Other things took over last night. Now I have seen the movement in all its detail and studying the chime and strike I can confirm this movement doesn’t auto correct, there is no wheels/levers resting on the cannon pinon in order for it to do such a thing. You just have a cam wheel (snail wheel) to the right which deters how many times it chimes. Also if I remember correctly the minute will only fit on one way because the fitting in not a complete square it has rounded edges on one side.
Dirty in many of the pinon leafs are you going to clean it?
@oldhippy thank you for your reply. yes it is definately going to get a full service, overall it is in very good condition but there is some work that needs doing ie. New screws and probably a few bushings. I took the mechanism out to look at because it wasn't chiming just to see what sort of problem i was dealing with luckily no major faults, it had just locked up and the hammers were very sticky.
I hope you have a very strong good clock mainspring winder because those springs are extremely powerful and could break your fingers or your wrist, wear a thick pair of gloves.
  • Sad 1
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
    • Some of the Chinese tools ae great and can be purchased at a fraction of the price of Swiss ones, some are complete garbage and some I'm convinced are coming out the same factory as the branded ones.
