IWC SAV Calibre 74 balance staff pivot broken and balance bend!?
14 hours ago, TibiV said:
Hello Nicksilver,
Thank you but how can be repaired ? Something I do not understand?
BR
Tibi V sr
I'm assuming your question is regarding the fact that the arms of the balance rim are not true anymore? The repair is done once the new staff has been rivetted and the roller fitted. The balance is held by its staff in a set of truing calipers, and then the rim is literally bent back in to true.
There are good descriptions of the process in standard books like Fried's Watchmaker's Manual, and perhaps other members have links to online resources.
as a reminder before you change the balance staff make sure you measure the old one then measured the new one and make sure they're exactly the same size. It tends to be the older the watch there tends to be variations so you don't want to be surprised after the new staff is in.
then bimetallic balance wheels with split rims due to attend the get bad out a shape. Depends on how soft they ours to how easy that is to happen. So if you replace a balance staff you almost always have to straighten it out. If it's really badly bad I find you can just straighten it with your fingers before even putting it in the truing caliper.
Then at the link below is all sorts a nice stuff to download but you want to go down to the section titled Joseph School of Watch Making. Ideally if you're new to watch repair you should download every single section and read the whole book. Butfor now you want section number two it explains how to true a balance wheel.
https://www.mybulova.com/vintage-bulova-catalogs
Thank you JohnR725, this is very helpful!
On 10/1/2022 at 10:55 PM, grsnovi said:
If you have a replacement staff you will need to remove the old staff and install the new as shown in Mark's video here.
Other videos that may assist:
You may want to try to source an entire replacement balance/cock and hairspring based on your (apparent) relatively "novice" watch repairer status.
Hello,
Thank you , I saw all Mark YouTube videos  but I cannot find that one that he is truing a balance ? can you help?
Hello,
Thank you for your effort , I do not have an issue to fit a  new balance staff ( last month I fit a new balance on an Omega 40,6 L , same  balance Breguet coil)  but the balance was perfect, my issue is how to true a balance wheel. As you can see on the picture , the balance is not true anymore . Never had this issue  and I do not want to start to repair without seeing somebody doing it , because this IWC 73 is a beauty and I will be proud to make it work again.
But I not sure if Mark or somebody else in a video ( you tube ) made that repair , I was looking to all Marks video's , miss him , I'm looking to chronoglide, vintage watch services (  Stien is great) but I cannot put my finger on that video to see it again.
Thank you
I did make above the reference to the Bulova book. Before videos there were books that's how people learn things ideally even with a video I would find a scrap balance wheel and practice to avoid complications. But if you want a video here's a video and you will note that he referenced reading a book and he's not an expert but here's a video of somebody's journey with the truing caliper
  • Thanks 2
Excellent vid indeed. I now realise I have the wrong style of truing callipers. 😏
Excellent video, thanks for posting that @JohnR725
After fitting balance staffs to split balance wheels, I hadn't really considered that distortion around one side of the rivet could cause distortion of that shape.
When coming across a problem like that, (as I'm a home hobbyist on no schedule), I like to think about it for a day or so - it's easy to rush in and make things worse 😧
On 10/1/2022 at 9:39 PM, VWatchie said:
Here are some additional threads that you might find useful (especially the excellent illustrations made by @HSL).
Interesting reading on your first staff change. Not attempted one as yet. I have a fair few to do though. Lots of tips on your old thread 👍 Just a thought if you dont mind me adding, just about consideration to the opposite side of the main work. Probably just a matter of course really to check  any defects on the hub of the new staff ?
Brilliant video john. I didnt know about the diffent kind of nibs.  Check mine and it has both truing and poising. No index or mounting arm so something i will have to make. Now i have to buy a bigger lathe to make tools. Thanks John less money to feed myself and keep warm. 😅. Notice the drilled holes to allow the pivots to run through.
Edited by Neverenoughwatches
anybody hobbyist or professional if there's some problems it's usually best to think about it rather than jumping in.
I find often times people what make quick decisions basically end up painting themselves in the corner of the room before they grasp what exactly they're doing.
out of curiosity is this the way the balance wheel came?
Hello all,
I finished reading , as a Romanian and to read in an English technical manual it's really hard to understand properly . I do not have an old balance to practice  , but I'll figure out something until I will be prepared I will do not touch that .
But what you offered , book and video , photos and Knowledge is amazing , that's why I love this hobby , nobody keeps that info for them , they want to spread it .
SO thank you all and I will keep you posted.
Thank you all and
BR Tibi V sr
Get some used Vostok movements on eBay. Calibre 2409 and/or calibre 2414. Inexpensive and great for practice.
Good ideea  ,
I ordered 3 movements to repair for 15USD
Thank you
It was wobbling , the pivot was broken , after I dismantle it I saw that little disorder on balance, my friend told me he escape the watch on floor tiles  ( the glass is broken - that's easy - Cousins )  -  I was thinking , can it be from the shock?
    • Does it say 17 jewels on the dial or on the movement ?
    • Hello and welcome from Leeds.
    • Lots of rust on that hairspring Nev, would you even try to clean it up ?
    • How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
    • Once you have the collet closer bits off, and the pulley off, there are two nuts on the spindle. These must be removed. There is a large nut in the back of the headstock with two holes, remove this with an appropriate wrench. The front large nut comes off too. The spindle now comes out- but wait- there's more! There is a spacer between the outer races of the bearings; the spindle will almost certainly come out "assembled" with both bearings and this spacer (it can actually come out front or back-ways with the large nuts off the headstock). You have to manage to press out the spindle from the rear bearing, get the spacer off, then remove the front bearing, now you can get to the key.   Imagining you get it all apart without causing any damage to the bearings, now the fun part starts. You must apply preload to the bearings, and this is a very tricky endeavor. Basically once you have the bearings back on, and are in the casting, you snug up the rear nut (one of the two) on the spindle, checking the play of the spindle with at least a 0.002mm reading indicator, until there is zero axial play, then just a little more, then snug up the second nut to lock things in place. Of course snugging up the second nut influences the preload, so you can go back and forth a few times to get it right. Too much preload and bearing life diminishes, too little, and you get poor performance, poor surface finishes, ball skidding, etc.   When I replaced the bearings in one of mine many years ago, I was surprised to find that the bearings were regular deep-groove bearings, but of a higher precision class than normal. I replaced with dimensionally identical angular contact bearings, class P4. In trying to set the preload, I just about lost my mind, so called Barden (the high precision arm of FAG bearing makers, and who made my new ones) and a nice engineer told me that the folks at Leinen were either crazy, or really good- he also said it's 100% A-OK to set up deep groove bearings with preload like this, but best is angular contact. In this bearing setup, the standard way to do it is to have a spacer between the outer races, and another between the inner races. Leinen has the former but not the latter, haha. His advice was to make an inner spacer. The trick is it has to be the exact same length as the outer spacer, within like a micron.  Then you just tighten everything up and the preload is set, because the bearings (the new ones) are ground in a way that they have proper preload in that situation. Easy. Sort of- if you have the means to make the other spacer!   Just to note- Schaublin does the preloading as Leinen did on these on their lathes using angular contact bearings. There is a procedure in the manual, where you tighten the nut until axial play is zero, then a certain number of degrees more. This works on their setup as the nut itself locks without a second nut, and they spent the time to figure it all out in a repeatable way.   I say all this not to scare you off from dismantling your headstock, just to give a heads-up what you're up against to get it back to where it was before.
