Hello and good day everyone.  I'm still getting my feet wet with watch repair, and would appreciate your advice regarding some timegrapher readings of a service I completed yesterday.
I bought an older Jerome Piquot watch off of eBay.  I know nothing about the brand, I just thought the watch looked unique and thought it'd be fun to rebuild.  Considering I paid under $25 for it, I figured if I botched it completely it wouldn't turn out to be an expensive way to learn a lesson in watch repair.   It has an AS 1686 movement.  The service went really well yesterday and it has been running in for around 9 hours at this point.  I'm getting a beat error of 0.8ms.  This AS 1686 does not have an adjustable beat error stud, I know that I would have to remove the balance wheel and adjust it manually if I wanted to.  I'd like to avoid that if possible and just wanted to call upon the experience of here to see if 0.8ms is something they'd try to improve upon on this watch.
Here's dial up running at +5 to +6 s/d, and has a very strong amplitude considering I didn't replace the mainspring, but I was meticulous with the cleaning and did polish the pivots with my recently acquired Jacot tool and remove a bit of extra side shake in the mainspring barrel.
Here's dial down - running at -2 to -3 s/d with a slight amplitude drop from the previous position.
I feel pretty good about the service, and was encouraged to see single digits after a short period of regulation.  Would you bother with the 0.8ms beat error in this 60 year old movement?  Also, does the amplitude drop of 21 degrees between dial up and dial down seem within reason to you?  There is a bit more end shake in the 4th wheel than I'd ultimately like, but it is not so much that it would cause any part of the wheels to not be in contact with one another.  It just meets the escape wheel not in the center of it's pinion, but it is still in full contact throughout all end play testing between both the wheels.  As of right now though, I do not have a jeweling/Seitz tool needed to adjust for that.  I think it is as good as I can get it with my tools & skill level.  I'd appreciate any feedback you may have.  Thanks.
Companies I've done work for on both new builds and vintage repair stipulated a beat error under 1ms on watches with fixed stud holders (in 6 positions, haha). I recall in some Vibrograf literature, written before the advent of digital timing machines, they said anything under 2ms will have essentially zero effect on the running. So you look fine there!
Good information to know.  Thank you!
I would say that .8ms, your worrying about nothing.
On the other hand, 315 degrees, especially with a used mainspring,  sounds a bit high.  Are you sure that you have the correct lift angle entered?
I do not think that it would have any effect on time keeping but it would be nice to know if the information it was providing was accurate.
Good luck.
Shane
Edited by Shane
I suppose, your pivot polishing caused that difference. If a pivot end of the balance staff is falsely too high domed, this will happen in the corresponding flat position. How is your amplitude in vertical positions?
If you want to know, if xx ms is ok or not, that number does not yet tell too much (0.8 however will be ok in any case).
Essential is, how many degrees out of the middle is the balance in rest? That is the reason of the beat error.
The very same error of 5 degrees will show:
1,3 ms @ 28800, 300° Ampl. (B.E.= 5°)
2,1 ms @ 18000, 300° Ampl. (B.E.= 5°)
3,6 ms @ 18000, 180° Ampl. (B.E.= 5°)
That is why I regard the beat error in degrees only, which my PCTM shows. 2 degrees and lower will be near to perfect. Your 0.8 ms corresponds to 2.0 degrees!
Of course you cannot expect such sophisticated measurements from Weishis and Witschis 😉
Frank
For watches with fixed stud holders, 2ms is my "reference point" as to whether to adjust or not.
I think people get too fixated with beat error.
BTW the correct lift angle for the AS 1686 is 52° - which is the default on that timegrapher.
I just googled the lift angle for the 1686 and found it to be 52°, so I left the machine on it's factory setting.  Great info from everyone, I learned a few new things.  Thanks!
Rolex is another interesting company for timing specifications. All sorts of timing specifications fully wound up half wound even have paperwork you're supposed to fill out but when it comes to the beat error that's pretty simple. A maximum of 0.8 ms test in any one of the five positions they normally test.
11 hours ago, nickelsilver said:
I must be being very hard on myself in this case,anything over 0.3 and I'm starting to feel agitation .
Frank
I'm  thinking power reserve would be a little less with a higher beat error than acceptable. The balance wheel would want to come to rest at a sooner time period ?
Five positions ?  Do they leave out DD ?
  • 2 years later...
Interersting thread as always, but I have a random but related question. When I put watches on my timegrapher they are either in their case, or, a free movement that I just place gently on the base and clamp onto the crown. However - I see here in the photos the movement is mounted in a movement holder - Eureka! I think I should be doing that - why didn't I think of it before? But does the movement in a movement holder,  in a case or neither make any difference at all to the readings of a timegrapher ? Many thanks 🙂
Edited by Andy1970
Typo
That how I always mounted a bare movement Andy....in a movement holder. The sprung clip on mine has a load of tension and i worried that it would press up too hard on the barrel or bend the plate .
I think it can make a difference with some watches.  I few times has happened to me.....a completely bizarre reading....then reposition the holder on the tg to find that the trace is almost perfect. I guess it depends how well the movement design, case etc transfers the ticky tocks through the movement to the mic.
I have had a lot of variability but then most of what I have mucked about with are NH seiko movements and for me they tend to be not very good on my admittedly cheap movement holders.
Tom
When using a timing machine is very important how you hold the watch to get a good clean signal into the machine. For instance I've attached a PDF that talks about that and I snipped out an image if the watches case dump
The reason for the specific orientation is two separate purposes. The signal itself wall in the audio frequency range in reality is a vibration and usually the easiest way for a case stopwatch to get the vibration out is by way of the  crown. Then the secondary purpose is that the sensor itself is located at that and attached to the metal piece. Now the problem with this can be large heavy cases just do not transmit the vibration good at all no matter what the orientation. Or some watches like Seiko it has to of how it's mounted in the case perhaps a plastic movement holding ring so basically sometimes cased up watches just will not time at all and they will have to have the movement removed and placed in the microphone.
Then the microphone itself is actually been designed to hold movements like this
Ideally it's nice when you have a watch in the microphone that you not have the dial on. This is because having the dial on without having a case to protect it can lead to unfortunate problems. So when you're servicing a watch once you get the watch running before you put the hands style automatic etc. on it and place it on the timing machine like in the image above and get a good signal
but depends upon the timing machine and other factors you may not deal actually hold the watch in which case you could try putting it in the movement holder. You want to make sure it's a metal movement holder because that's better at transmitting vibrations and its placement in the microphone is critical so that you can get the signal to touch the metal at the end.
8643_WI_81 BASIC CHECKS AND SETTINGS OF A MECHANICAL WATCH_EN cousins.pdf
I found this on occasion as well.
On many a Timex, the spring tension flexes the plate enough that it actually stops the movement. I have found this if I mount the movement oriented such that the plate cutout that exposing the balance and regulator is receiving spring tension across it. Unfortunate too, because that is the safer and easier orientation to setup a Timex.
    • ive got a 3220 dd module here that i go back to every now and then an it never works correctly , massive pain as i love the watch i that needs it!
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
