Balance spring coil rubbing, how to fix?
Hi,
I've been working on an old hand wind Hawthorn Watch.co watch movement and have it all cleaned and oiled and put back together, but one stubborn balance coil is rubbing on the balance cock. I just can't seem to get it to lay flat, it was worse and I have made it better, but that last outer coil just won't budge.
Any suggestions on how to fix this? I'm super freaked out about destroying the hair spring of course.
Thanks for any help with this.
Bill
Hi Bill, not only is it rubbing against the balance cock, it's also all bunched up where your arrow is pointing.
If you remove the balance cock, lay it upside down on the bench and place the pivot into the jewel, it would be easy to visualize it.
It could be an easy fix or a nightmare, depending on how badly distorted the hairspring is. This is not a job for a beginner or those with a weak heart.
My advice would be to store it for the time being and come back when your skills have caught up with the problem.
Good luck and happy watchmaking.
Moving to correct sub-forum.
Why is this happening?
Please don't be offended - from time to time, in an attempt to keep WRT organized, we need to move threads to another area more suited to the subject of that thread. Members can help the forum staff by checking for a suitable sub-forum before posting as this will help to reduce their admin workload.
 Though this spring can be sorted as it is in the movement, as a beginner you would have a better shot at it if you CAN UNPIN THE HAIRSPRING FROM THE STUD, the balance assembly  would then  be easily detachable from the cock,  in which case you best take a picture of the coil for your reference and to show us, we will work with you to fix the fault.
You need to master detaching the balance from the cock for many tasks, including worse messed up hairsprings.
Regds
Thank you for the book suggestions, I will follow up on these.
I worked on this watch about 6 months ago and put it aside because of the hairspring issues. I thought I fully disassembled and cleaned the movement, guess I should go back in my notes and check, but you say it looks dirty, so maybe I should re-clean it.
I did demagnetize it and saw no difference.
Thanks for the help everyone.
    • No matter what I did, I could not get the amplitude more than 240 deg. At least there is 0.2 beat error and minus 1-2 s/d.  So, probably not the happy end I would have hoped for, but still I think the watch turned out quite nice. You be the judge of that. Thank you everyone for your help!
    • its used to lengthen or shorten the suspension spring from the front f the clock dial, this in turn will give regulation to the clock. Try inserting a pocket watch key or even better the double ended key for the clock into the small aperture on the dial at the top and turning it, you will see the suspension block either raise or lower. If it raises the clock will run faster if it lowers the clock will run slower
    • Grateful for info regarding the nature & function of the horizontal cog and the unit it's on top of in the picture. It meshes with a vertical cog (enclosed in the unit) on the arbour which is supported at its other end by the back plate of the dial unit to which it is not quite perpendicular...
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
