How do I remove this? And help with identification
1 hour ago, albertopveiga said:
Hi everyone!
I recently got a small Meister-Anker that I’m servicing mostly for the sake of practice. When disassembling it, I came across one of the wheels which goes through the plate, and I’m not sure how to disassemble. I don’t want to break it! Anyone could advise?
Hi albert. Be careful with these, a second hand pinion drive wheel. I broke the first one i encountered. The wheel is a press fit and can be tight. There is a presto tool that fits between the arms of the wheel. I found it easier to remove the wheel on the underside.
Just make sure you pry off the wheel from the central hub, otherwise you'll bend the wheel removing it. When the wheel is removed check that it is totally flat before assembling back on with a staking tool.
Also, the wheel you need to remove is the one with four spokes, not the five spoke wheel, the five spoke wheel is part of the wheel train. So, when staking back the four spoke wheel it is critical you get the height correct so it engages with the sweep second pinion exactly in the middle of itimage.png.54b9d89cb14ca2aeec17ef3f0c702521.pngimage.png.66027570fd86abbc4dc8101b87892d8b.pngimage.png.9274f58a81bfd9a70244faec61ca35e9.png
Edited by Jon
  • Like 6
7 hours ago, Kalanag said:
That 5 spoke Presto tool has been out of stock for months now. It shows stock coming soon, then the date shifts again lol. I’ve been using @Jonmethod above, but I would really prefer to use the Presto tool. I have a few very expensive watches coming in - hopefully that Presto tool is in stock soon.
2 hours ago, oldhippy said:
If you do not have the correct tool my advice would be leave it alone, you could easily damage the wheel or break the pivot.
Agree with OH, I did on my first encounter with one fortunately it was a relatively cheap watch that now has no second hand. The 17CS. English Smiths watches which i have a few of t is very common to see this. I wont touch them to service until i have the correct tool.
I managed to remove one by prying from underneath, it seems a slightly safer option. But i would really like the tool for it
12 hours ago, mikepilk said:
As a home hobbyist, rather than buy the 5 and 6 spoke tools, I bought the Bergeon 6016 tool. Useful for removing wheels, hands, rollers etc
That's an interesting tool. How do you use it?  Flat and round side, which side goes against which part? Sorry, I'm a bit dense, just not able to visualize how this is used. 🙂
Thank you everyone for the great answers and advice!! This did the trick for me, lacking a better tool. I think I haven’t broken anything… but I will know more when assembling 🙂
Thank you!!
I slide it in as shown - flat side up. The end is very fine.  I just used it to remove a roller. It works really well.
  • 7 months later...
Me too... "how hard could it be I thought..." It came off OK.. or at least it seemed to, but when I put it back on I pressed too much creating friction between it and the mainplate, so I had to remove and re-apply. I think a combination of it trying to spin with friction and the re-application caused the ID of the wheel to open up and then it wouldn't stay on the pivot. One (expensive 😭) Bulova resigned to the ever growing "I'll fix that another day pile".
However it still irks me to the point where I still cannot bring myself to order one, that the presto tool to do this job is £45.15 + VAT + P&P when I can get the 99% the same hand removing tool (non Bergeon) for less than £10. I know its a false economy not to get one.... but the tight Geordie in me will not let me do it 🤪
Same 👍but yorkshireman. Not just our region that makes us tight here, Its the hobby, if i spend a lot then i like to see larger items for my money. 🙄
I bought a cheap presto tool and tried to file the ends to be like the Bergeon, but without success. The metal was poor quality and I couldn't file to the precision required.
That's why I bought the Bergeon 6016. It's not cheap at £33+VAT, but you can use it on 5 and 6 spoke wheels, hands and rollers.
The tool that removes these wheels has already been posted. I realize many of you do this for a hobby, but sometimes there is no other way unless you want damage the movement, so unless you have to remove it I suggest you don't which I have all ready mentioned many posts back.
Fair point
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
