Postal Clock
RogerH
Hi, I've just picked up this charming little postal clock. Looks to be in good order but I'll find out more when I strip it down. Early 20th century Lovejoy & co. My one query are the weights, I only thought cone weights came with cuckoo clocks....any thoughts? And any other information is always gratefully received.
Hi  the weights are cuckoo clock ones, I repaired one two years ago and re weights were lead encased in a brass sleave as per the picture below. I have had tow of these wooden framed clocks the second one had copper chains not brass. Also when dismantling take many pictures, the bearings are brass inserts into the wood and the hour wheel used a type of soft rubber compound as the friction from the mains haft to drive the hands.
They do come with what are called fern weights. I have even seen them with ball shaped weights. There are variations with pendulums many are long thin wires others are brass or wood.  You should be able tell by the crutch and how wide  space you have when you tread the pendulum through. Mid Victorian I would say and more then likely the movement is Black Forest German. Also know as Wag on the wall clocks.
Look out for split brass bushes and inside roughness.
I didn't know postal clocks were like that.  The plates/frame - it's all wood.  The pivots of the wheel train turn in bushings in the wood!  I don't work on many clocks, so I've never seen that before.  Are there many kinds of clocks that are made that way?  Anybody know?
12 minutes ago, transporter said:
Mines now on its way to the test stand shortly
That's a good picture!  Plenty of detail.  I wonder how many of my family member's old clocks had bushed wooden frames like this.  This is very educational.  I'm going to keep following this post.  I also have to call some of my brothers and cousins and see if anyone still has some of the old clocks from our ancestors.  I may talk them into getting pictures of the works.
EDIT: you know, @oldhippy, you may turn me into a clock repairman yet.
Edited by KarlvonKoln
I have one of these on the wall, Its problem is the hand drive. It uses a ruberised compound in the center of the hour wheel which has shrunk a bit and will not drive the hands correctly so will have to think of some way to resurect the material or replace it with a rubber bush. As its mine its in the que to be done
6 hours ago, oldhippy said:
That's come up very nice. Did you need to treat the wood frame with anything to nourish it? Only sometimes you find cracks because the wood has dried out, caused by central heating. Never put clocks near central heating radiators.
Old hippy, I’ll be taking the trains out and giving it some treatment with some danish oil. The plates had some splitting but bushes were tight and surprisingly not worn enough to warrant replacing on the higher wheels.
hopefuly it will come up looking better than it does now
  • 3 months later...
Hi
I know this is an old post but Old Hippy asked what danish oil is, it is an oil (tung or linseed) with varnish added usually 1\3.
Useful topic as i have two of these tucked away in the loft somewhere, purchased in a job lot from an old watch/clock repairer.
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
