OK, this one has been bugging me for a long time!  Anyone have a method for efficiently getting a small drop, or maybe two, out of an oil vial and into the cup in your oil stand? It seems no matter what I try I end up wasting at least as much oil as I capture in the cup.  At one zillion dollars a milliliter seems a damn crime!
Stuff I've tried with no great success:
  • Pick up a small blob of oil on the end of a polished steel rod and transfer to oil cup (50% of the oil stays on the rod even after treating with epilame)
  • Attempt to pour from bottle (major mess and waste, quantity uncontrollable)
  • Hypodermic syringe: at least as bad above methods
Not that Moebius is interested in us their using oil efficiently, but it seems obvious they should pack the stuff in a dedicated syringe -- easy and precise dispensing and zero oxygen storage.
Anyway, until that happens (never!) what works for you?
Eyup matey. What was wrong  with the syringe?
Most of the oil/lubricant you put in your oil pots are going to be cleaned out the next time you refill your oil puts anyway, since you are supposed to change them out weekly. The actual amount of oil/lubricant going into your movements is actually quite little.
That being said, I find that using the largest oiler you can find to transfer oil/lubricant from the bottle to your oil pot works quite well. You have to do it multiple times (more than 10 times) to get your oil well filled to a necessary depth, so the amount remaining on the oiler after you have filled your oil pot is actually quite little, in the grand scheme of things.
@Neverenoughwatches,
I am also thinking the syringe is the answer (especially in 30cc size which I have plenty of as a consequence of operating another business that specialized in offering people holistic health solutions for their pets).
What's your experience with a syringe and why wouldn't it be ideal for conserving material like watch oil?  After all, they are designed for use with super-expensive (and dangerous) drugs, so surely they're OK for handing M9010?
Am I missing something?
g.
29 minutes ago, Kalanag said:
A syringe for pet care from Amazon:
The black seal on the (disposable) syringe plunger is lubricated with silicone oil.
Also, I think the amount of oil taken out with a syringe would be way too much for a week’s worth of oil in an oil pot.
If you really wanted to go down this route, an Eppendorf 20uL mechanical pipette would be better than a syringe, but those are very expensive. You would also have to use disposable pipette tips.B833D30D-A15C-4CA2-9F1E-4168B37F5771.thumb.jpeg.9c6868da385def896cb9855bce3cfebb.jpeg
Edited by ifibrin
12 minutes ago, ifibrin said:
The black seal on the syringe plunger is lubricated with silicone oil.
Thanks for this important remark! The syringe incl. plunger should be cleaned before use. I use a syringe out of glass.
With a 1 ml syringe you are able to dispense very little drops of oil.
Edited by Kalanag
I work in Chemistry research, and I’ve never been able to clean out the silicone oil on these black plungers… the silicone oil always appears in analytical work if you use these types of disposable syringes. The silicone oil doesn’t affect water based solutions as used in medical patient injections etc, which is where they are meant to be used.
The largest oiler I have appears to pick up around 1uL of oil (visually, not sure, unable to measure), so by using it repeatedly, I transfer enough oil into my oil pot for a week’s worth. The residual oil on the oiler is small enough that there’s little wastage.
Edited by ifibrin
Hello @ifibrin,
I'm not 100% clear on what you mean by what you wrote above - are you saying there is a potential for tainting watch lubricants if a syringe featuring the "typical" black plungers is used?
Do you think that risk exists and therefore syringes should not be used?  At what quanta of risk are you talking about?
While performing background research on my upcoming paper "How (and Why) We Clean Things" I have come across several resources with respect to silicone oil.  For example, several solvents for silicone oil are listed in the following article:
https://www.shinetsusilicone-global.com/products/type/oil/detail/about/index2.shtml#:~:text=Silicone fluid is highly soluble,ethanol%2C methanol%2C and water.
Along with a handy chart:
https://www.shinetsusilicone-global.com/products/type/oil/detail/about/index2.shtml#solubility_chart01
Finally, here's a very easily read chart of silicone oil solubility results that you may find useful:
Source:  https://www.shinetsusilicones.com/p2502.html
Cheers,
g.
Why don't you guys just use your tweezers? Dip a properly cleaned #3 into a vial, open them slightly to "suck up" the oil between the prongs (capillary action) , then go to your pot and open them fully to dump the oil. Job done and no issues with cross contamination. Repeat if you need more, but usually once should be enough
Edited by gbyleveldt
  • Like 6
I saw Marshall do that on video once, it looked pretty slick to me (pun intended).  😆
g.
I am new here....Is silicone contamination a problem I need to be aware of?
17 hours ago, Gramham said:
Hello @ifibrin,
I wouldn’t use disposable syringes that have plungers/gaskets lubricated with silicone oil because I’m worried that the silicone oil will contaminate the oil. I haven’t actually investigated the solubility of silicone oil in Moebius lubricants, but I don’t think it’s far fetched that silicone oil is miscible in watch oils…
If you are very careful with your syringe and don’t allow your watch oil to contact the plunger head when you suck a small droplet of oil in, you may be able to avoid contamination. However, this is still a risk…
I use a large head pin, stuck into a short length of wood cut from a bamboo chopstick. The pin head picks up a lot of oil. For thick oils like D5 or HP1500, usually a single dip is enough. Thin oils like 9910 would require a few more.
I'm OCD, so I use a separate dipstick for each type of oil. I even use a different oilers for each type of oil. My mentor taught me to stick the oiler in a piece of pithwood to clean it. But unless the piece of pithwood is disposed of very frequently, the different oils will mix in the pithwood and cause cross contamination.
So, what do you think? Do I need psychiatric help?
This activity is all about splitting hairs.  If the rest of your practice parallels this level of attention more power to you.  If not then yes you need help.
Shane
Hello @ifibrin
My plan was to pull the plunger up a bit, leaving an air gap and just load the steel tip.  The other thing I could potentially do is clear the steel tip with one of the listed solvents to reduce the presence of silicone oil to a nominal amount, but that may dilute the watch oil in the process if I am not careful.  Do you have a suggested protocol from your experience in industry?
g.
@HectorLooi,
I don't think so.  In many respects OCD may benefit you as a Watchmaker as it would likely prevent laziness and corner-cutting.  It's more a matter of how much rather than if when it comes to Obsessive-Compulsive Disorder (OCD).  We see a lot of it in the University system, and I've received special training in terms of identifying it and dealing with it in students...and by extension, colleagues.  You would not believe how fanatical academics can be about the littlest things.  Many of you on this platform probably see more than a little "fanaticism" in my postings.  Besides my natural inclination for developing meaning, I've also been trained to "go deep", usually way deeper than normal.  🙂
My own oil management protocol is going to be pretty much the same (atomicity and separation), so it's not crazy.  The loading technique you mention is quite good...and inexpensive, and simple - so I'm going to copy that one if you don't mind.  It's a lot simpler than cleaning and loading a syringe that is known to be tainted with silicone oil.
I also like the "tweezer" technique...why don't you use that?
g.
Edited by Gramham
Tweezers have always worked well enough for me, but in my case it doesn't really matter what technique I use, I always end up making a mess anyway.
Oh well.
3 hours ago, Gramham said:
Hello @ifibrin
I wouldn’t use a disposable syringe at all when doing analytical work, unless the disposable syringe is one of those without the rubber plunger. Those are more difficult to find. Best practice is to use a Hamilton glass syringe with PTFE plunger.
However, if you plan to use a steel needle and only use the volume inside the needle to transfer watch oil, it should be ok. However, you need to use a new needle each time. Not sure if that is economical.
Take a look at this website https://www.medicaldesignandoutsourcing.com/what-is-the-difference-between-two-part-and-three-part-syringes/
“Occasionally a researcher or engineer may have difficulty identifying the source of various contaminates in their process.  Sometimes the source is either the rubber or silicone oil found in common three-part syringes. If that becomes apparent in your process, there may yet remain another low-cost option by way of a two-part syringe. Two-part syringes are slightly different because they do not use a rubber tip on the plunger to create a vacuum seal.  Instead, these syringes have been specifically designed to not introduce additional materials such as rubber or even silicone oil.”
Edited by ifibrin
This is the dipstick that I use. It's actually made from a dental ball-ended clasp wire but a large head pin will probably work just as well.
For grease, like 8300, I have an old dental grease applicator called a Lubrimed. The grease is loaded into a PTFE cartridge and loaded into the applicator. Turning the back cap advances the plunger which squeezes out a precise, controlled amount of grease.
They used to be given free with every handpiece but they are practically extinct now. Ebay has some going for about USD $60 each.
I just use a little glass eyedropper with a small rubber bulb at the other end.  Easy to clean if I need to, and I never suck up so much oil that it touches the rubber.
How about gluing an oilier into the bottom of the oil bottle cap?  Extra oil on oilier goes back in bottle when you screw cap back on.  no waist.
The idea is brilliant! My only concern is the cap material (PP? PE?) which can not be glued reliably.
I use an oiler and the principle that you can vary the loading by changing the speed at which you remove it from the bottle. Submerge a thick clean oiler in the stock bottle and remove it quickly and you’ll have a nice drop to move to your pot. Do the same thing with a slow removal and you’ll have next to nothing clinging to the oiler (which may be what you need when actually oiling a jewel).
Many members have many ideas and ways of retreiving oil,  in the past In have used a screwdriver, oiler, tweezers. They all work, it depends on how much oil you need to deposit in the cup, so its horses for courses.
I use a large oiler that was made from a small piece of aluminum rod with the end flattened. Delivers about a "drop" into the oil cups without minimal loss. Easy to clean up and maintain.
    • ive got a 3220 dd module here that i go back to every now and then an it never works correctly , massive pain as i love the watch i that needs it!
    • I'm a little confused here before servicing everything was fine and now it's not? Then I'm assuming if you run it without the chronograph modular runs just fine or does it give you problems then? Then as far as tightening goes I've occasionally seen people use a staking set and sometimes it works sometimes it doesn't. You can also disassemble and flip it over that sometimes works. Otherwise try eBay and maybe one will come up. There is a tiny possibility if the Problem is on the gear part and not on the center tube that you could purchase a shorter version and pop it on your longer version that's a speculation on my part that may be that might work but if the tube itself is worn then you're going to have a problem then it's back to eBay and just try to find one in the first place all sorts of things will show up on eBay sooner or later.
    • Why do you need a whole balance assembly (balance complete)? Staffs are readily available and cheap.
    • Hi welcome to the forum. Enjoy. dictionary_ebauches_sa.pdf TZIllustratedGlossary.pdf
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
