Hello Everyone,
In what feels like a continuing quest to find a pocket watch movement that is (a) the right size; (b) the right type; (c) well-documented and (d) not overly exotic I have finally been able to procure an American-made Elgin Pocket Watch movement.  I really want to start leveling up my physical technique, but it's been hard to find a practice movement to work on.
Basically, right now, I suck at manipulating the teensy-weensy stuff.  I have already had a few mishaps with little bits of watches I really shouldn't be working on because they are too small for me (Seiko 5, Dollar Watch, 5-Bar Pocket Watch) flying to whereabouts unknown in my work area and hours on my knees with flashlight and magnet in hand to (possibly) retrieve them.
I am terrified to open anything running or of value now, because it's obvious that my technique isn't up to grade.  Problem is, here in Hong Kong, the only timepieces that make it over the Pacific are unusual, exotic and as a result kinda expensive.  I have been purchasing what are relatively inexpensive movements from the (very) limited choices available only to discover that they often feature obscure Swiss cylinder movements, British graham-syle movements, American pin lever movements and so forth.  I have a healthy pile of that kind of watch now, but I really don't feel ready to approach them with any confidence.
But, finally...I got this movement in the mail today!
https://pocketwatchdatabase.com/search/result/elgin/23687805
Dial Up:
Dial Down:
So I have a question:  I'd like to start with something really simple, like getting the rust off this movement.
I want to start with the Winding Work.  Does anyone have any advice regarding doing this in a way that won't mess up the wheels?
Should I just de-rust them and leave them stained...or should I attempt to make them "look nicer" by trying to attempt some kind of abrasive art on them?
Any and all suggestions welcome.  I am new at this and I want to start off on the right direction in the right way.  I have lots of time.
g.
I would sand them down and try to get the grain as straight as possible on the last few passes.
Most flat surfaces have some 'surfacing' to help stop the spread of oil so a polish may not be the best thing. A straight line rough finish using sandpaper may not be as good as the original geneva stripes or perlage but may be better than a fully polished surface.
rgds
Anilv
I understand how you feel and when I say that every thing has value, there are limits.  After hearing how Mark was tasked with a cheep alarm clock to practice his manipulations, I first took apart dozens of cheep quartz watchs with the understanding they were never going to work again.  These watches often have parts so small that ladies mechanical movements will feel massive afterwards.  I still have several little containers of screws, hands and one of jewels that I removed from them.  Everything else was scrapped.  I would think that this type of movement would be readily available in Hong Kong.
The best of luck.
Shane
2 hours ago, Nucejoe said:
Heres a matt finish.
https://www.watchrepairtalk.com/topic/11449-matte-finishing-ratchet-and-crown-wheels/
In case you can top this work, will you share your technique with us.
Thanks.
Hello @Nucejoe
Thank you!  It's so wonderful to have people like you taking the time to point me to well-developed, existing threads so I don't go all "reinventing the wheel" on you guys.  Right now I am Black Swan learning mode ("I don't know what I don't know") so any and all pointers and input are most gratefully accepted!
Thanks again!
g.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
    • I believe so. I thought about it the last time.
