Information about this clock
LittleWatchShop
1 hour ago, clockboy said:
Art deco period for sure. However a first for me a three barrel Westminster chime clock with a platform escape
Its a bit odd this one to have a platform and not  the normal pendulum and such an early date. Myself I have two Elliot Westminster chime clocks both with platforms.
Finally received this clock for repair.  Actually, the clock is running fine...just missing a minute hand.
Here is the clock with a prototype minute hand I printed with 3d printer.  I think the proportions are right.  Not sure if I should flip the hand or leave it in the mirror image position.
Next is to find an appropriate metal to fabricate the hand.  Or...just leave it as 3d printed...dunno.
Thoughts.
34 minutes ago, dadistic said:
I was trying to envision how it would look when both hands point at 12,  and they are overlapping.   Still not sure, but I think not mirrored ?
Cheers!
I can flip it easy enough.  I have searched and searched for this clock to see but have yet to find it.  At the end of the day, I will let the owner decide.
I have fabricated a metal hand using the 3d printed hand as a template.  Not perfect.  In particular, making the square hope perfect size and perfectly aligned proved difficult, but I think I have a way to fix that.
Here it is...still needs more tweaking, polishing, and then painting.
My starting material was a clock mainspring.  First annealed and flattened and then started the cutting.
Edited by LittleWatchShop
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
