Seiko mainspring barrel
hello all I have turned my attention to my mainspring and while it was in great condition and very clean I have striped it down and cleaned it.
spring in good condition no bends and in tack.
now do I grease the walls and oil the spring or just grease the barrel wall ?
you didn't say whether this was a manual wind or an automatic? Basically make sure the spring is nice and clean depending upon whose philosophy of mainspring lubrication you look at. If it's an automatic you put breaking grease on the outer barrel wall of suitable type. Then if you're falling Seiko's recommendation they have a lubrication that they put all over everything if you could find it. Or you can put no lubrication on the mainspring because are supposed to be self lubricating otherwise you could put some 8200 grease. Remember to lubricate the barrel arbor also
John thank you yes sorry it a self winding barrel.
I'm not looking forward to doing this by hand to be honest it's really eating at me and it's anti clock wise or left handed wind 6# left hand spring winder.
I'm looking at Bergeron  6# do I need a handle or can it be done with out the handle ?
my funds are running really Low I was wondering if some kind soul would wind this up for me if I paid them to do it. just a thought
the mainspring winding issue is kind of a universal if she was Seiko is. I did a quick search online because others have done this before us and hear there's suggesting a number seven of course left-handed. of course it does depend on which Seiko barrel you have C could measure the diameter and look at the winders themselves and get one that's just a little bit smaller so will go in. But maybe better not read all the text it looks like it can be an interesting process which it really shouldn't be that bad but.
https://www.thewatchsite.com/threads/bergeon-mainspring-winder-07-update.255746/
So I've watch this youtube video and I think he is putting far to much grease on and in side his barrel I thought you wiped the oil on the spring as a thin film and just add three points of grease to the barrel wall
so you are not watching all the video time stamp 8.20 and 12.18
The winder number you need depends on the barrel you're working with. For example, if you're working with a 7xxx Seiko movement, then you need a #6 winder with a left handed arbor, for a 61xx/63xx movement you'll need a #7 winder with a (#7 or #6) right handed arbor.
I'm using the winder without a handle. I wish I had one, but it is not a must.
About the grease, as always there are many techniques, some use a pice of watchmaker paper to spread a film of grease along the spring and some install the spring dry and then put four dots of grease on top of it. I personally put four dots of breaking grease on the barrel wall and then install the spring with the film of grease on it.
Edited by aac58
I see in the video he uses 8201 as a breaking grease, not the first time I have seen this on YouTube videos.  8201 is not listed as a breaking grease.
Anyone got any thoughts on this
All brake greases have a content of dry lubricant such as graphite, MoS2 or PTFE. The 8201 is a grease with MoS2. The wholesaler Flume says: „For switch springs, levers, pins, automatic main springs.“
Edited by Kalanag
8 hours ago, grsnovi said:
Maybe the next one you work on will need the 6.
it would be a real nice world if we only needed one main spring Winder. The reality is you probably won't use every size in the set but having a set is nice. At work we have the complete Bergeron set. Then the Bergeron ETA set size for specific calibers. Mainly the big differences is the handles they have to be the right size to fit the center part the white spring is don't like things that are too big or too small. Then there is the older set for the blued steel Springs which have a much more aggressive hook on the end. Typically if you use those on the modern white Springs you might not actually Billy got off because it's sticking out too far inside. Then I have one more set entirely different for pocket watch Springs.
but you would think we'd have enough and we don't. Because occasionally Springs won't fit what they're supposed. Today's fun was a Waltham that too small for my set and the center part was too big for the standard sad I think I had to use the older set as it was the only way to grab the center part I do remember having both sets out and having to pick and choose. Unfortunately you can't have enough watch repair tools as you're always going to be short of something.
lubrication of anything in horology is interesting subject because everyone has a different opinion for variety of reasons.
that is a really interesting choice for breaking grease? This is basically the 8200 classic mainspring grease with a little bit of Molybdenum bisulfide (MoS2) which basically makes it a really nice high pressure lubricant and not really a breaking grease at all. It may be because he uses so little of it that's why he gets way with that if you use too much I think you'd have premature slipping.
third link below is your lubrication website. Like for instance he lubricated the harbor with and he gives you the number which you find out is really the HP 1300 lubricants. Which is a interesting choice because it has a problem? if you look on the lubrication website and download the lubrication chart as it's only place I can find this on the bottom of the chart you find this The Synt-HP oils (9101, 9102, 9103, 9104) are preferentially in use for ruby bearings. For brass bearings, we recommend Microgliss D-4 or D-5. which becomes interesting because in arbor is made out of steel and typically the barrels are made out of brass and they're not recommending the HP oils? Which works out fine in my case because I don't use oil on the arbor I use 9504 which is a high pressure grease. then yes the maker of the lubrication is telling you to do something different than everyone else in Swatch group maybe they didn't get the memo?
We've covered the lubrication of barrels before that's what the first link is but you have to scroll way down to get the lubrication parts I just reposted it all here.
the images come out of an Omega document conveniently Omega watermarks all the corners with where it came from so I just knew about the images to avoid complications. They have a document on what they call recycling the mainspring. Typically I can a Swatch group service center they do is replace the entire barrel. On modern white Springs typically they do not use lubrication on the mainspring itself. They do use of breaking grease P125 properly applied. Then they lubricate the arbor with and yes I know they didn't get the memo if there was one HP 1300.
then missing because a in snip out all the images a whole bunch of stuff on checking the barrel checking the arbor fit checking that you have the proper end shake. In other words you didn't bend the lead when you're moving it. Then the cleaning procedure. The mainspring is wiped off with a lint free cloth no lubrication's applied.
Then there is the interesting thing the barrel of courses washed in the cleaning machine and afterwords the drama arbor and led have epilam applied. We've discussed epilam on this group somewhere multiple pages basically it's there to prevent the spread of oil. I have a suspicion without proof that the HP oils tend to spread on anything other than Ruby jewels and steel. I think that's what the cryptic meaning of the quotes on the bottom of the lubrication chart on the website is telling us. Which is why I don't worry about oil and I use grease.
then in his video when he puts the arbor in using tweezers ideally you should use a pin vice and they actually makes special pin devices just for arbors. Because they don't always going in as nice as that and if you're holding a really tight with tweezers arbors can really fly.
the second link has a video it shows what happens if the breaking grease is too strong. Towards the end he lubricates with something you were never going to get which is Rolex breaking grease. My understanding from somebody uses it yes they use lots of it exactly as he shows. My experience if you did the same thing with P125 because I asked somebody who did not tell the truth on how much or how little I should be using if you use that much the mainspring will barely slip at all. Which is why the Omega document recommends small amounts evenly spread.
https://www.watchrepairtalk.com/topic/9982-eta-2892-a2-automatic-works-what-else-can-i-do/
https://youtu.be/7KNTrHVD088
https://www.moebius-lubricants.ch/en
John first I have to just say what a detailed and wonderful reply we are really lucky to have someone so well informed and with such knowledge.
I do hope you didn't spend to much time replying to my post, I hope a lot of it was copy and paste
thankyou so so very much for taking the time to reply to my post
James
James
Hiya Tiny. John is an absolute gem dont you think. Worth his weight in gold.
Yep I was going to say I owe him a drink or two BUT I've just seen where he lives but if he sends me his paypal email I will send him a pint or two
On 5/11/2022 at 12:17 AM, Tiny said:
o'bugger i've ordered the wrong size i've ordered a 6 when it should be a 7 i suppose 1mm is not to much of a size difference
I’ve mentioned here a few times on the forum. I use a #7 arbour and a #6 winder it works fantastic for these 7xxx main barrels. You can also use a #7  arbour and #7 winder, but the #7 winder is a little thicker for comfort. Also, you need a flat washer spacer when using a #7 winder to space the spring enough to make proper contact with the hook in the winder. And remember you need left hand (blue) winders. I use a super thin layer of 8200 on the spring prior to installation and then 8217 as a braking grease on the inside barrel.
I’ve made two videos showing it working, although I can do up a detailed video if you’d like?
Edited by gbyleveldt
have I trashed my main spring.
I was fitting my mainspring for two or three  time when on the third time it sprung open again but this time I didn't get away with out kinking it in three places. I managed to remove most of the the kinks by rubbing it along a screwdriver but their was a little bit of evidence that there was a kink in it.
Really not as easy as it looks on marks video
should I replace the spring or chance it. The kinks are in the end where it's near the barrel walls.
What did you use to insert the spring T ?
I have a winder but the spring is still on it.
I have just read that while hair springs can be repaired it's a  bit different with mainspring to much force
This unfortunately is a classic problem in watch repair the assumption that watch repair is easy. Mark is an expert at watch repair he's going to make everything look easy. Typically any time you see a YouTube video on watch repair nobody's going to want to look stupid they're going to make everything look easy and wonderful.
The unfortunate reality of watch repair is you're going to break and destroy things. This is why in school situations they typically have practice movements and they spend lots and lots of time practicing on the same disposable movements. They don't jump in and start working on live patients after one watch. To be good at watch repair you have to practice a lot to be honest to be good at watch repair you have to practice continuously all of us are currently practicing were all getting better.
Then I assume this is a practice watch is it not?  You still need to practice putting the mainspring in you need to perfect her techniques so you can put it in without destroying it. Technically you have destroyed it but you can still practice with this it gets expensive if you have to keep buying new springs and destroying them so practice with this one until you get it in a perfecter technique and yes it probably will be an issue but the practice will be well worth it for the future.
Been there done that T. It didnt end well. The fit is the best you can get if you want it to go smoothly
Edited by Neverenoughwatches
can anyone recommend a spring that is say £3-4 new left hand wind I can buy to practice with to use in a  size 6 or 7 winder. I have opened my spare barrel and the spring is kinked it two places and that's before I remove it from barrel so I have ordered another movement but I need to practice I can get to the double end but finding it hard to feed it bur I think I have a solution for this bend a small bit of soft soldering wire in a (c) to trap it so I can feed it without stopping.
Tiny
new left hand wind
You don't have to buy the special left and wind mainsprings because they don't exist. The left and the right Springs are identical. It just means that one goes in the barrel one direction and the other goes in the barrel the other direction.
As you don't need a special left-handed mainspring that doesn't exist I would look at eBay for generic mainsprings as you don't need to buy one for a specific watch you just need an approximate size range and eBay tends to be pretty good at finding mainsprings
@JohnR725
Thank you for the information I do have another Movement coming in the post, should arrive end of the week.
I do  have a observation from my practice on winding springs, I hope you can answer. So I had my second spring that was damaged from the start yes it had two kinks in it from the start so I went from having a spare spring to a practice spring but when I tried to use it as a practice spring I noted that it was slipping on the winder arbor, I could hear a click in side and it stopped advancing inside the winder so not only a kinked spring but also a stretched spring  where the arbor is fitted.
so this would I think have an affect when winding the spring when the watch is all restored and surely running poorly. How would this problem be solved. would it just be the case of replace.
Tiny
    • Post some pictures , some good close ones of the parts you've described.
    • Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. Ive never used epilame H only information i have read and mentally stored about it mostly from Nicklesilver here and elsewhere ( the fork horns thing ), maybe the residue powder that is removed has some grinding effect ? So probably a good idea to limit its application areas to only the absolute necessary. Yes as far as i know epilame rubs off relatively easy, the technique of running the watch to make a groove through it first in the pallet stones where the lubrication is then placed. This i understand creates the barrier for the lube to sit up to. If i can find a good balance of pros and cons of its use then thats one process i can avoid by using a thixotropic lube on the stones. The epilame i would say allows for a more fluid lubrication to be used that would increase amplitude on low beat movements. The stearic acid powder is extremely cheap, the problem is the fuming process to coat parts, is not selective , the whole part has to treated in this method. If epilame residue can cause wear then thats not good, if I remember the conclusion was not proved entirely just a general assumption between watchmakers. The thread is out there somewhere, the same discussion is also old on a facebook group. If its a potential problem for amateurs to use then i would prefer not to take the risk .
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
