Rebanking on a Valjoux 72
I ordered a tap 1.00 stem for the moment C01.211 & a new Tissot gold crown for the watch! I’ve tried putting it back in pressing in the detent button, but it feels a bit springy when I try to put a bit of pressure on it? Do you know where I can get a parts list & a brake down of the keyless watch parts details!
By jenepa7356 · Posted
I believe I have identified a strap that would fit flush against my watch. It's this one. Ideally, I would like to add a white stripe to the strap. It has a raised section already where I think a two-tone splash would be welcome. Trying to research how to do this has not been very fruitful. Sometimes it seems as simple as a sharpie, sometimes the recommendations are something potentially hazardous to your skin (but, it would be facing away from the skin generally...). Does anyone have any experience or advice for this task? Luckily it's cheap enough I don't see the harm in ordering one or two to play around with, which is a welcome difference from what I usually have to put up with!! -
that type also allows removal of broken bits easily....
