Hello folks. I'm having great time. Watch repair is great fun. Although I'm not in the zone for repair, at present I seem to be destroying everything.
I need a main spring for the movement of a pocket watch. Can anyone tell how I can tell what spring I need. I am a basic novice.  I don't mind criticism as long as it is constructive. I have dissembled the movement. The main spring kept winding but not tightening. Opening is as seen. New one needed.
Regards
Ross
Edited by rossjackson01
grammar
I was able to find the exact part number for my Elgin grade 313 by going to: pocketwatchdatabase.com however I know the model and serial number of my movement.
As @praezis says, you might not need a new spring. Does the arbor engage with the end of the spring?
Optionally, if you know the height of the spring, the thickness of the spring and the length of the spring you can go to:
https://www.cousinsuk.com/category/filter/mainsprings-by-size-watch-pocket
and by matching the end hole patterns they will make an effort to suggest a spring.
Let us know how it turns out.
Replacing a pocket watch mainspring is the same as a wristwatch mainspring. If you can identify who made the watch you can look up and see what supposed to be used. Otherwise you just measure the dimensions and find another spring.
The only complications you run into typically with pocket watch springs are specific types of ends. Like T type  and there's a variety of other ones very common on American pocket watches.
It would be nice to have a picture looking straight down on the barrel so we can see the entire spring in the barrel. Can't quite see where the end is as you seem to trim that often all the pictures? But it looks like a standard tongue type in spring. Also looks like it fills the barrel up nicely it's not too short I would just pull it out and measure it and get another one. If you give us the dimensions we can look at our mainspring books and see what probably is. Typical mainspring measurements are based on the width – thickness and length. Sometimes there's a fourth dimension which is the diameter the inside of the barrel in other words if you expect to build this shove the mainspring and without a Winder. These are more common on wristwatches.
As requested. Photographs of the movement and spring. On the movement there is a number sequence 345858 the last number may be a B. Anyone any information for me please. I've never taken out a main spring. I'll try it tomorrow.
Regards
Ross
From one ear images I snipped out what I was looking for. A classic problem with pocket watch mainsprings are getting the correct  end. This appears to be a poorly made tongue End. It looks like from the barrel it was supposed to have a tongue end. Often times they would've had something protruding for a hole lens spring. Or perhaps this mainspring had a hole and was modified to be a tongue but they didn't do a really good job.
Now if you get us the dimensions we can look in the catalogs and see what might fit and whether you go have to modify the end etc. You can also look carefully at the edge of the barrel to see if barrel modifications had been done.
Expand
 Your mainspring is far from a tight grip around the barrel arbour,  the catch of the arbour does catch the eye on mainspring , but will slip out easy if spring isn't tightly wrapped around the arbour.
The spindle seems broke somsomeone rigged it, you need a new spring, as said if you gives us the measurement length, width and thickness a suitable general resort spring can be found to work in your watch.
My goodness. You lot are so good. I've done as suggested. I closed the spring centre down then released it a little. Inserted the arbour and hey presto! It winds. Now, using the photographs, I am going to commence the rebuild. Woohoo!
I repaired the keyless works. Someone had unscrewed the setting lever and it was miss hitting. Gosh, its great fun learning.
Regards
Ross
Expand
Hi there. Will do for practice but you are sure to see low power reserve and weak torque out of the barrel.
There is actually no way of knowing about the condition of the barrel specially the barrel wall other than taking the spring out, clean the barrel and inspect and more often than not, the spring should be replace with a new one.
Regds
I'VE DONE IT!!!!          I'VE DONE IT!!!!      I'VE DONE IT!!!!
Sorry for the shout. But, I've actually got the pocket watch working. I'm sitting here, looking at the movement, and its ticking. Yes, ticking.
Put the Keyless works together. Can wind up, the train wheels move, the motion works are OK. Fitted the balance. Movement, shake, kept going. Still going. It's not perfect, I can see the balance wheel is not square on side elevation. Runs like a wobbly car tyre. But it's ticking when the movement is flat.
Way to go!!!!! A well into the future project to make it fully functional. But, I'm on the way.
Can you tell I'm excited?
Regards and thank you to all
Ross
🌟🌟🌟 Congrats Ross! 🌟🌟🌟
I remember so well, and will never forget the first watch I got ticking after a service. An unbeatable (ha-ha)  feeling and one of the happiest moments of my life.
Expand
Congrats Ross!
I'm waiting for the same jolt of excitement but it probably won't be for a week or two as I'm waiting on a mainspring winder. At least my $200 worth of oil showed up... 🤨
Expand
It was fabulous. Still going 14 hours later (and counting), still excited.
I only have two bottle items for oiling. 1 watch oil and one grease. £5 each. My set up is on my computer desk.
Adding a photograph of my workspace. Video of the balance wobble.
Regards
Ross
This is a video on YouTube of the balance wheel. Wobbly it is. But it's all mine.
https://www.youtube.com/shorts/gnhmSmDbOJw
Ross
Well done Ross , Just watching its heart beat gives a lot of pleasure. The balance needs truing but probably at a later stage as skills devlope but you have done a great job in getting it working.  Like the workspace although it would benifit from a better mat but with linited space a nice little sertup. I see you have the PC up there do you have the timegrapher Sware on it?.
Expand
Thank you. I have replaced the mouse mat with a special repair mat as suggested. The cut box has saved me losing springs a number of times. Twanged the arbor 3 times. Hit the wall and bounced back into the box. Phew!
Timegrapher on PC?
I use the PC to watch the YouTube tutorials. Play/Pause whilst attempting the repair. Great fun.
Regards
Ross
There is a Timegraher S/ware  watch-O-Scope that runs on a PC, The lite version works basicaly as a demo with no print function but runs well enough The licences version  Around  $50  it requires an amplifier and pick up for the watch  Have a look. I think that there is now an amp and pickup ready made now I made my own and it all works very well.     all the best.
Thank you folks.
I decided to do a full disassemble, clean and oil. Opened the container. Sneezed. Now I can't find the second hand. Aaagh!
As an aside. Anyone any idea on the watch movement make? I thought Omega, but cannot see any makers marks apart from the number mentioned. 345858 or is it 34585B. The balance cock motif certainly looks like Omega ones I have seen on YouTube. But nothing really matches. ????
Regards
Ross
    • Thanks for the information, its a big help. I'll try and pull off the pipe. I think I'll try using the Presto hand remover. Then I guess I'll try to fit the pipe into the hands(?) though maybe I won't have to as I'm putting a new set of hands on the movement.
    • One of the problems with chronograph hands and whoever manufactured the watch would be that often times they are put on with considerable force. The problem with the amount of force they go on with is that often times when removed they disintegrate. So disintegrating hands unfortunately is quite common on a chronograph. With those lucky enough to have an account with were be authorized by whoever made the watch or the service center they would have a complete package of hands. so yes that does look like the brass tube of the hand that disintegrated.
    • The unfortunate problem of the three jar cleaning machine. At least I assume it's a three jar machine. Classically with three jar machine the first is a cleaner and the second to be a rinse of the same type. Cleaning is a interesting process and it's not exactly cleaning and rinsed the entire procedure is cleaning. The cleaner is supposed to have chemicals to put things in the solution and things to make things right and shiny. The rinse continues to put things in solution and reduces the concentration of things in the fluid on the plates. Ideally you should have two rinses not one and alcohol. If you look at the modern cleaning machines you find typically now they will have a minimum of four jars or whatever. Often times the last one will have alcohol because depending upon where you live the rinse itself may not evaporate. So you have a final rinse of alcohol just to rinse off the rinse. Then the only thing I've ever seen on baskets would be this quoted below from something Omega has. But they are assuming that you have genuine Elma baskets and not a machine made in India from unknown materials. Although a lot of people are using the baskets from India I just don't know enough about them. Personally I've see in the baskets for other machines especially the holder which would be as it's implied below nickel plated where the plating wears off and eventually the brass will be etched away from the chemicals in the cleaning product. One thing I didn't see you mention was how long in the each of the baths? Usually for the cleaning products that make things bright and shiny. Time-limited approximately 4 minutes works really well. The rinses of less of concern it depends upon how much the cleaning fluid is dissolved in it though. You can download the specifications the cleaning products I like they have recommended times the final alcohol rinse is supposed to be relatively short as any time we mention alcohol and watches people get excited over dissolving the shellac. But typically with isopropyl alcohol it takes a little while longer and I've even used alcohol which I know dissolves shellac but I was just using it to rinse off the rinse so it was never a problem.
    • I think i am done. I was working withe two pieces, one was 316 SS and the other 304 SS. The starting material for 304 was thinner, so I opted for finishing it. Since I only have images of one of these watches, I cannot know the exact dimensions. The owner is not critical...just wants a working solution. I think this is it. It was quite the challenge to turn the inside  locking rim. An inside angle cut. Had to be damn close in order to have a snap fit. Frankly I think I just got lucky. Sometimes lucky is better than smart! The inside edge that interfaces with the crystal is an interference fit. This was on purpose in case my locking-edge cut was overshot...then the bezel and crystal would work together to stay put. Tens of hours working on this, and I learned a lot!
    • I'm using: 2.5L Elma WF Pro – New Formula for the main cleaning 2.5L Elma Suprol Pro – New Formula for the first rinse Isopropanol Alcohol IPA 99.99% for the final rinse So far, all fresh fluids. I was also under the impression they shouldn’t cause rust, so I’m wondering if maybe the damage was already there and is just progressing now. Because my baskets came with the machine when I bought it pre-owned, I’m not sure if they’re original Elma or not. That’s exactly why I’m hesitant to buy a new set—I don’t want to end up with lower quality clones again if that’s what these are.
