I have been struggling to hold a small hairspring stud so I can attach a new hairspring. The stud is the friction fit style.
Has anyone got any tips or tools advice how to hold steady will I insert a pin . I have tried rodico,tweezers etc but not luck as yet.
It may be useful to secure the stud in the balance cock. I find it easier this way.
Thanks Mark, Tried that but I think the new stud post is a bit bigger than the hole on the balance cock. Will have a measure up to see if that is the fault.
Robert this is really small the screw holding tweezers are just to big. Noticed today there is a tool by Bergeon 30207 for the job but a lot of money £140
The only thing I can think of is a jewel picker upper, you know those little sticky silicon ended tools? but I can't imagine whether it would work in this scenario.
Oh wait, I think i misunderstood what you were trying to do.
You need something like a fine pin vice to hold it securely?
Sometimes I find that the only way is to make your own tool. When working with accutrons I have found that hyperdermic needles of different bores are useful raw material to be pared down or shaped with a Dremel or simply drilling fine holes into plates to wedge / stand small screws or posts into while you work on them works for me.
Hope it helps,
Cheers,
Vic
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
