Japy Freres four-glass service
LittleWatchShop
Here is a clock that belonged to my great Aunt who likely bought it in France in the latte 19th century when she lived over there.
It has been displayed in my home for a long time and now I am servicing it.  The clock was serviced four previous times by a person who also did clock work for my Dad's business.  He was a machinist and quite skillful, but I am somewhat disappointed by the work I see here.  Moreover, he marked it serviced four times over an eleven year period.  That seems excessive to me.  So, it is a bit of a mystery.
Anyway, I am showing pictures of the tear down here.  I have cleaned it, and it is reassembled and running--in test phase.  I will post other pictures later.
Because of the warnings I received here, I did not use ammoniated cleaner.  Instead, I used Dawn soap in water in an ultrasonic, and then rinsed in alcohol (not the drinkable kind!).  Not so pretty of a result, so I did use Brasso on the back plate...the one that will be visible.  Then I did another clean in the ultrasonic with an alcohol bath.
The regulator on the ones I have seen has a spring detent on the regulator sprocket.  It was not present on this clock.  A fella gave me a box of French clock movements like this, so I pinched the detent from one of those.  It looks factory now...and works properly.
Edited by LittleWatchShop
15 minutes ago, LittleWatchShop said:
The picture does noes not accurately convey color.  The case top and bottom is green marble.  Seems unusual color for marble but I am no gemologist, so maybe it is not so unusual.
Yes you can get green marble in a few countries around the world apparently it is white and depending on the minerals in it give different shades of colour.
  • 2 months later...
Having a problem with this clock.  I had put aside until now.  It runs for awhile and then quits.  When it quits, it is way out of beat.  Not surprising, because of an issue that I was already aware.  The verge slips on the post.  You can adjust it and get it in beat, but over time, the thing slips.  Here are a couple of pictures.
Is this normal...threaded like this?  Any suggestions on how to tighten?  Needs to be more snug, but cannot be fixed (e.g., with loctite) because it must allow for adjustment.
Hi LWS It’s been liberally dosed in solder in an attempt to solve the problem at some time. Best approach I guess is to clean off the solder turn up a bush that’s a tight fit on the arbour then drill out the crutch and broach untill the bush is a knock in fit. You could leave it tight or solder it but a cleaner job than the last one. It has probably been threaded in an effort to gain a tight fit. Is there a makers mark on the back.  eg. AB Mougin or Japy ferrets or the like ,
12 minutes ago, watchweasol said:
Japy ferrets
Yes.  Here it is.
This clock belonged to my great Aunt.  Now my father was the baby of the family and came late and I was also the baby of the family and came late, so the gap between me and my grandparents was so large that they died before I was born and at a ripe old age.  My great Aunt was born in the late 1800s and was a trained musician--trained in France.  She lived there for some years.  Now doubt this clock was acquired while living there.  The repair marks (barely visible) were made my a man who did contract work for my dad (especially complicated clocks).  He was an expert machinist and I was always in awe of his shop when I visited (which I did often).  It surprises me that  this was his solution, frankly.  Since this was a family clock, there was no money to be made on the repair, so maybe it was an express fix.  We did not have a lot of money growing up...enough, but not a lot.
Hi LWS. They are quality clocks and worth a bit of effort in fixing. The only problem is the pivots they are glass hard and don’t suffer abuse. Is the pallet jewel Ed or polished steel, Some on the brocot escapements were ruby pallets , very fine.
Ithink we all were careful growing up, we were the same although the garden and the chickens helped a lot  never hungry.
  This is what I would do.  Clean all that dreadful  soft solder off. If you have the correct tap and die use them and see how things fit. If unsuccessful re bush the crutch and tap it. If by chance you cannot clean that solder from that crutch you will have to make a new one drill a small hole for the crutch to go in and use Loctite Threadlocker Red 271
This is a very nice French Four Glass with cloisonné and mercury pendulum with a very nice dial. Worth a few hundred pounds. So it need plenty of good care when cleaning and repairing such a piece
    • if you're trying to keep track of conversations scattered all over the message board emails are an absolute must.   looking at the bell icon on the top of the page versus the emails today it looks like I got the correct amount of emails. So making some minor change based on the one of the images up above I started getting notifications again. But at times I still have a suspicion that something isn't quite right. I have some feeling that the message board may delay sending emails until something so seems to be a long delay between when you get your emails just a weird feeling things aren't quite right oh  and then even though I do seem to be getting emails I no longer get notifications of personal messages I don't find that out until I arrived at the message board where I'm pretty sure I used to get notifications of those two. So something is definitely changed on the message board. then for everyone not getting emails you do want to check your spam folder. I have found that sometimes were open up an email the system I use warns me that it thinks the email is evil and bad and I have no idea why he thinks some of the emails are and some are not. But this is actually the program I use not the email system which also has a mind of its own as to what it considers spam so you should always check your spam folder.
    • 10.46 according to Google. What do I do with it once I have the measurement in lignes?
    • If you Google "site:watchrepairtalk.com Unruh" it should answer your question. https://www.google.com/search?q=site%3Awatchrepairtalk.com+Unruh&sca_esv=cd1cd8ba04cfc6b9&rlz=1C1BYYL_svSE993SE993&sxsrf=ACQVn08-tJuTdvkJ1CZdy5PcUR7BB6zDaQ%3A1714681373604&ei=HfYzZtTBJPf8wPAPnsySiA0&ved=0ahUKEwiUxLTx5e-FAxV3PhAIHR6mBNEQ4dUDCBA&uact=5&oq=site%3Awatchrepairtalk.com+Unruh&gs_lp=Egxnd3Mtd2l6LXNlcnAiHnNpdGU6d2F0Y2hyZXBhaXJ0YWxrLmNvbSBVbnJ1aEjfCVAAWABwAXgAkAEAmAEjoAEjqgEBMbgBA8gBAJgCAKACAJgDAIgGAZIHAKAHLQ&sclient=gws-wiz-serp
    • If you loosen the case back does that make any difference?
