Eta 2836-2 repair and issue
Hello all,
i hope you are well!
Can somebody help?  an ETA 2836-2 for repair , The issue = balance spring, found a balance complete, replace it, now it's working  perfectly only when the watch is face down, face up have a sound like balance is rubbing something, how can I determine where is rubbing? face down is +- 3 sec /day  face up  - 546 sec /day?
The balance spring is perfect .
Thank you
Tibi V sr
One common error is using the wrong screw for the pallet fork bridge. The correct screw has a very flat head to clear the hairspring. Using a wrong screw will cause the arm of the balance to hit the screw head.
The pallet bridge screw not being fully tightened will also have the same affect.
rgds
Anil
rgds
Anil
Thank you for idea, but it's not the case here , when it's with face up will be bigger distance from the pallet fork bridge
10 hours ago, mikepilk said:
How much balance endshake is there?
If it's too much the balance could touch the centre wheel or balance cock, or, the roller could be rubbing on the pallet forks.
The first one has the same endshake with the second one!
 A side view of the oscilator when running with focus on the coil , balance wheel ,  roller table, underside of the cock , whereever can possibly rub.
Do you have the amplitude and beat error? could this be rebanking your hearing.
Loose regulator and stud arm can also make a sound.
I can hear it with my ear , on tester it's s horror , amplitude is low 165 ,  -546 s/day beat error is almost ok 0,5 when face down, +-3 sec/day , amplitude 230 and beat error 0,2 it's an   nerve killer! I'm thinking to paint the balance to see scratches
Often a close up video shows what naked eye usualy miss.
Often oscilator will ( eventually) come to a stop if the balance rubs.
The  amplitude isn't high enough to cause rebank.
Adjusted end shake  keeps the balance in about the same hight in DD and DU positions, Mike asked and commented about the end shake, we still have don't know  the amount of end shakes.
Regs
Hello,
End shake is about 0,2 - 0,3  it's normal, it's not stops the balance, I left in the face up pos to see if will be same scratches, for 24 hours, to see where it rubs . Under microscope nothing.
So I will have to make video and to see it in slow motion! good idea!
Thank you
Hello all,
On slow motion video I saw that the balance had a slight vertical motion and was knocking on the balance cock and my supplier send me a replacement and now it' s working perfectly!
So thank you all for the ideas and best regards
Tibi V sr
    • I've been contemplating getting one of these for some time now, after working on a few spring loaded centre seconds pinion movements. It's not an absolutely necessary tool to have, hence the procrastination.  Then it hit me, all I need is a flat base with a screw in it. So I scrounged around for something suitable and ended up with this. This is some rubber thingy that is  supposed to stop furniture with casters from moving around. In fact, any flat material with sufficient thickness to hold the screw in the centre would do.
    • I think your axes are mislabelled here. They need switching around.
    • @clockboy Thank you for the response.
    • @Knebo Thank you for the detailed response and reminding me. I went back and introduced myself. That's really good information, for 15xx it should be similar. Will dig deeper into that.   Yes I mean that. Attaching some pictures. New to shooting through a loupe so pardon the quality. I don't quite get the strength point, could you elaborate? Seeing the punch used for the job, it should limit the highest point of the metal being pushed, Maybe a worn out punch?       I haven't checked the axle will do that, but thee watchmaker told me that the 9'o clock side has been over-polished and the caseback is sinking on that side which is causing the issue. Armed with this knowledge, I will investigate both. The Picture would certainly suggest that plus the Intense pitting (wrist perfuming habit of my family) might be contributing to how the caseback fits.      Thank you again, I have made a checklist and will be investigating all the points you mentioned.   Rolex told me that they will replace the dial and bracelet so I didn't go that route. Its an independent watchmaker, and a very well reputed one in online and offline collector circles. I have seen his work and got work done from him before, this is the first time something like this is coming up. Maybe he is getting lazy in sourcing good parts. lol.
    • 😞 I hate the heat, i work outside in winter in a t shirt .
