I think jdr is suggesting you buy a book on the subject. He probably meant this one: The Modern Watchmakers Lathe And How To Use It (Archie Perkins). I don't have that one, but I can recommend TheWatchmaker's and Model Engineer's Lathe: A User's Manual (Donald der Carle) or The Watchmaker and his Lathe (Hans Jendritzki).
Thanks Guys, Yeah it was care and maintenance I was interested in, plus any technical info that may be available. The lathe will need some restoration before I use it so looking for information on correct lubricants to use. The lathe cross slide is missing it's tool post so any recommendations on replacements would be appreciated. The headstock is missing two screws which look like they are used for applying oil, and the screws that hold the pulley hub to the headstock spindle could do with replacing.
Thanks for any advice
I will check out the books you recommend, thank you.
17 hours ago, nickelsilver said:
I've never seen a manual on a Wolf Jahn lathe in 25 years of looking. I figure they figured you'd know how to use it if you bought it, but that's 60+ years ago.
Do you have any specific questions about it?
Hi, Cleaning and lubricating is the first port of call with the lathe, correct procedure to dismantle was what I was hoping for with a manual. Plus I like manuals 🙂
  • Similar Content
    • does anyone knows what type of battery this digital Watch takes?
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
