Spinning Hands
Willow
Hi all, any advice after this single train platform escapement was working then all of a sudden the hands started spinning round, nothing else .as far as i could see thought it might be the clutch but that seems ok. Thanks
Are you sure you have the depth of the contrite wheel correct? The way of telling this is the movement should still work no matter what angle the movement is in, it should still work up side down.
It sounds as if it is more likely to be the pallet stones as already mentioned.
I can think of a senerio for this,  pallets moved after running for a while due to shelac having been lost during the clean.
movement was only cleaned in warm water and the escapement wasn't cleaned at all just oiled
9 hours ago, watchweasol said:
Hi Willoe  Is it possible for you to remove the balance and a close up of the pallet and the pallet stones.     cheers
Hi watchweasol yes will do in this photo the arrow pointing to the screw i did remove that what is the signifinance of that screw, thanks
53 minutes ago, oldhippy said:
Here's a thought. The center wheel is friction tight I believe held in with a pin that fits in the recess of a spring on top of the center wheel, has the spring worked it's self out part way or all of the way.
Hi oldhippy all i can see is the center wheel has a clutch with a pin through to hold it in place see photo at start of thread do you mean that thanks
5 hours ago, oldhippy said:
Yes that is it. As I said I wondered if the pin had worked its self out as that would cause the hands to wiz round.
checked the clutch it's ok watchweasol wanted some photo's of the stones just going to do that now
Just now, RogerH said:
Am I missing something? Where's the pallet? this should be where the two pallet stones fit? Rocks between the Balance spring and the Escape wheel...has it pinged off?
Me too somethings missing. The escape wheel will just run with no control.
Is this it the photo you want
Hi Willow  I am still of the opion that if you remove the balance complete and expose the pallets and escape wheel you will be able to inspect the interaction of the pallet and the escape wheel locking or not locking as may be the case. the other thing is the engagement of the contrate wheel whick Old Hippy mentioned earlier. If you have bad engagementit could ruin the platform amd the wheel. An other point to check is the contrate wheel tight on its pinion and not slipping.  cheers
yes the interaction with the pallet and the escape wheel is not right the escape wheel is just rocking back and forth when i set the balance wheel in motion never worked on one of these is it easy enough to take apart
    • Never seen that but yes very practical Hector
    • Welcome, Simeon! I'm into Soviet watches too (not the political system, and yes, I am able to make the distinction, unlike some). They offer amazing value for money. I like your "Big Zero" profile image. It's a true classic and I have one of those myself. I noticed that the hands aren't the original. Not that it matters a lot but here's an interesting article about the Big Zero if you haven't already seen it.
    • I was thinking will the gasket stretch at all to match the desired size.  Did i also deduce that the original gasket is thinner (0 .5mm ) than the cousins gasket ( 0.8mm )  could that just be an effect of you measuring the case for the gasket size  H  ?
    • if we look at and understand why steel becomes magnetised and unmagnetised then its possible to work out why some devices are better than others. Simpy it is a parallel alignment of atoms , electrons within a material caused by external magnetic fields. Different magnetic fields cause different alignments and non alignment of atoms. Fields by AC currents are changing atom direction approx 50 times per second ( 50hz ). As a material is drawn away from a demagging device the field is becoming progressively weaker while also changing the material's atom direction having the effect of returning their random directions ( demagnetising ) . To improve on this demagetising effect, try changing the material's orientation as it is drawn away.  Fields caused by DC currents have the most permanent magnetising effect as the currect is flowing one way only. A good demagger would produce random magnet fields and disorientation of the material's atoms.
