I received the Horia clone and so far am pretty impressed.  Hadn't used it yet though.
I also got an Epilame bottle that I will be using for cleaning pallet forks and balances.  Far less money than the crazy expensive ones I've seen.  Has a mesh basket to hold the parts.  A glass marble sits in the neck to reduce evaporation while the bottle is upright.  Silicone gaskets to keep it all sealed up.  Hopefully, they will hold up to solvents such as Hexane.  A bit larger in size than I expected.
https://www.aliexpress.us/item/3256805561125727.html
Edited by gpraceman
I'm having hard time understanding where exactly is the epilame bottle needed. Is it not the same just having some small glass bottle and picking the part with tweezers? Maybe it's handy for treating multiple parts at once but I only submerge escape wheel. I treat pallet jewels with oiler.
It's just easier to pick out the treated parts from the small metal basket than the bottom of the bottle, especially the cap jewels used in shock settings. All the time you are trying to pick them up the fluid is evaporating, also the small neck helps reduce fluid loss due to evaporation. But a definite 'nice to have' rather than a necessity.
Ok for cap jewels I definitely understand. I use oiler for the cap jewels too.
I forgot to mention cleaning jewels.  I'll be using this bottle for cleaning those, balance wheels and pallet forks.  The current bottle that I was using lets the Hexane evaporate too quickly.
Has anyone tried the Chinese bezel remover tool with 4 wedge blades, a blue knob, and red aluminum base? Cousins may sell it too. The prices I see on it are suddenly about $20 lower than I remembered and it's moved from "not until I need it" into "sure why not" range. Unless it's junk. Thoughts?
I recently got one as they seemed so cheap, £16, and I'm surprised at how good the quality is.
I also bought a screw extractor, as that seem cheap, about £13. I haven't used it yet, but the quality seems OK.
Edited by mikepilk
I have. My experience is that the blades are soft trash. I prefer this https://www.cousinsuk.com/product/microshock-case-opener-horotec?code=C0310
I got the Bergeon version and although it works very well the tip of the rods that press against the screw easily disintegrates (can be bought as spares). So, my advice is don't press harder on the screw than what's required to get it turning.
I got this type of bezel remover from CousinsUK, and have had no problem with the blades. The screws holding the blades, however, are "soft trash". Noticed it when I tried to tighten them.
Does anyone have experience of this hand removal tool? I guess it's for hand fitting too? Now I have a very cheap and wobbly hand press. There's so much play that it's like doing everything free hand. This one's $176 in Ali. Any hand press suggestions?
https://a.aliexpress.com/_mPo00bmScreenshot_2023-10-21-12-07-54-297_com.alibaba.aliexpresshd-edit.jpg
Edited by Malocchio
I have one and I have had issues with it. The pushing needle is not exactly aligned the relevant holes and slot so it is extremely fiddly. I have only used this tool twice so it might just be me being cack handed.
Edited by clockboy
5 minutes ago, mikepilk said:
I bought a hand press, but find them fiddly to use. I prefer just to press them on by hand. A removal tool for chrono's is useful. Have you got the price right - I see it for £48 ($58)
There are different prices for parts of the set. Complete set is $176 for me. I like to press a little with tweezers and finish with a press for some precision. That tool doesn't seem to come with any hand fitting attachments but according to description it should accept screw-in Bergeon pushers that cost like £17 a piece.
Is the needle used just for keeping the hand from falling when lifting the hand? Have you used it as a hand press?
Thank you for the comment on the screw extractor. Ordered one.
Edited by rossjackson01
Spelling, Grammar, more information
I don't have the movement holders for each specific movement, I just use a Bergeon 4040. So if the movement isn't sat exactly flat, and the often aren't, then the above type of hand fitting tools are no good. Hence I find just simple hand held pushers under a microscope work fine.
On 10/21/2023 at 8:58 PM, GuyMontag said:
I have one of these and really like it.
One more thing. Don't you need to have many different size movement holders with it? The one I linked comes with four different sizes but even the biggest, 11½ Ligne, is too small for average Seikos. Larger holders don't seem to exist except for obviously the Bergeon ones that cost a lot.
Yes, although you don't have to. However, if you use the holders designed for the press then you don't have to worry about lining up the holder to get the plunger aligned to the center hands, which for me is one of the biggest benefits of this press. With a normal movement holder you can make it work by covering the holder mount with something flat but then you have to align the plunger to the hands every time. Of course, if doing a chronograph or sub-seconds watches you need to move the holder regardless.
Someone uploaded a 3D design so you can print out a platform for the press. You can also 3D print the movement holders so you can have a custom holder for any movement you use with the press.
Edited by GuyMontag
28 minutes ago, GuyMontag said:
Yes, although you don't have to. However...
Thanks for the quick reply. I just noticed this was discussed on a previous page. I knew I had seen the discussion but somehow didn't find it with the search. I ordered the press and a Bergeon 5409 copy too.
    • Update, I discovered that I could change the mainspring by removing the arbor and sliding it out from between the front and back plates. So I put a new mainspring in. This it what I  get over a 7 day period After winding                                          amplitude is 1 1/2 turns plus a few degrees.        ie just over 1 1/2 turns. 1 day after winding     gained 1 sec      no amplitude check. 2 days after winding   gained 1 sec      amplitude 1 1/2 turns        i.e. it lost the few extra degrees 3 days afer winding    gained 3 sec     no amplitude check 4 days after winding   gained 5 sec     amplitude 1 1/2 turns        i.e. unchanged 5 days after winding   gained 7 sec     no amplitude check 6 days after winding   gained 16sec    amplitude just over 1 1/4 turns 7 days after winding   gained 24sec   amplitude 1 1/4 turns. From  Based on video inspection, I am getting full pallet lock. So, my data seems to be at odds with the statement "swing of a balance wheel has nothing to do with the rate". However, I have noticed the banking posts are not controlling the lever position on the right side.  I may have some work to do here.
    • I can't tell whether or not some stem is stuck in the crown, I  think so though.  If the crown is stainless steel you could try alum to disolve the stem of try drilling it out. If all else fails, buy a new crown.
    • Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • I think maybe we're all a bit dim @ManSkirtBrew 🤣 99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance. So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
    • At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out. I'm genuinely surprised I've never read about anyone else doing it, to be honest.
