Older Pallet Forks and Shellac
Just a random thought, I just cleaned a movement and inspecting before reassembly. Pallet forks seem to be "shellaced" on one side. Does the Shellac ever age and need reapplied, seem that opposite side could have new applied and insure feet don't come loose over time.
The pallet fork looks fine, no issues with chemical or current setting. Just curious.
There are a lot of topic regarding IPA other harsh chemicals that dissolve shellac, I learned the hard way and switched to L&R fluids. Topics talked about different evaluations of how quickly shellac was being dissolved, but not on age and insuring movement's longevity. Especially concerning with the vintage movements I've been working with...parts are a bit hit or miss, obviously.
(Ultrasonic with L&R 111 for 10 min, #3 rinse for 5, second #3 rinse for 5.)
Pallet stones are normally only shellaced on the under side with no issues, there's no need to add more mass to the fork by adding more shellac.
This regime shouldn't cause you any issues. There is some debate about u/s baths and shellac although I've never had any issues and a lot of pro-cleaning machines use a u/s stage. There is also some concern about excessive first bath durations as some cleaners can have a less than sympathetic effect on plating. Unless you're dealing with something really stubborn you should be fine with just 5 mins in the L&R111.
I have worked with 150 year old Shellac on impulse jewels and palat forks with no issue at all.
I just reshellaced a pallet fork last night. The watch is a Titoni titoflex which I bought from an eBay seller from India. The watch was running but the positional error was unacceptable.
I found that the shellac was missing on one side and the other side was cracked.
When the OP said "shellaced" on one side, does he mean this?
Typically with pallet forks the shellac is usually fine even with vintage pocket watches. But you do always need to check just in case.
In the case of the roller jewel or impulse jewel in a pocket watch you always check to make sure they're not loose. There isn't any reason why the shellac should break down but more than likely if its vintage somebody's change the balance staff is always worth checking to make sure the roller jewel is in tight.
    • I'm guessing, but this commercial demag machine maybe produces random magnetic fields to re-randomise  the iron particles. So heres one for you, synthetic rubies are coloured predominantly with chromium oxide . But natural rubies and old synthetic watch rubies were also coloured with iron oxide in higher percentages than chromium oxide. Which gave them a degree of.................🤔
    • I've never had a hairspring distort on me by passing the movement or just the balance in a plastic pot over this demagnetiser. Have you seen how fast a cleaning machine spins to spin-off fluid and that does no harm to a hairspring. I was a little concerned when I first used it, thinking it might be too strong, but I was wrong. It is strong, but it does no damage. I pass the part over the demagnetiser and keep going for about an arms length, so about a metre, to properly demag the part.
    • I don't think you would be able to find spare parts. Your best bet would be to get a new movement from eBay. https://www.ebay.com/itm/256508500506?itmmeta=01HY3M863PSA61GK7B859QCWTE&hash=item3bb9191a1a:g:ubgAAOSwrJJgPP-s&itmprp=enc%3AAQAJAAAA4DxWhpiQiz2ZjKpm3PS%2FHPh4IafsSzMWEobc2q4qQWgPGMZ8kCR8y2PRsm7GE31FjeSDYSWcEyGlrpZEdQyyzOSgsgsaPjbP7dYmK8r49Nh%2BEtSqDDIZ8Tbp3vvX035fFXgcjc1GEH8l%2FOWJ9aTeWNGzeBgUwqyhJ3ZSXji50TQr6rd38Sqwaqsj2oc51UVKqqIKySKTfxVB7X09EXcJsmeYc5GCdVODNkb02q2RsxfSIzpgl9dFCmW1Ih%2BPg2j2NziSELg5AfaHl%2FPU2Zn9fNnoVN1Z1NUAREyh2BCubcWC|tkp%3ABk9SR_bhoPTwYw
    • Here's a thought. Try unscrewing the bezel and the crystal. If you have one of those sticky balls for undoing casebacks, I would give that a try.
    • Last week I noticed my Eco-drive's second hand was stopped at 12 o'clock. I left it in the sun for a few days and no change, so I figured it was time to replace the rechargeable battery. I've had this guy for at least 15 years. Replaced the battery and the seconds hand moved to about 5 o'clock and stopped there. I let it sit for a day in the sun, no change. I took the battery out and tested it, and it's at 1.4v. The old one was at 1.0v. I'd like to test if it's charging. I've been looking around for diagnostic info, but only been able to find the owner's manual. Anyone have a reference for it?
