Most, if not all Omegas have a serial number. I don't see one on this watch. I'm no expert on Omega, but the watch movement you have pictures of doesn't appear to be of particularly high quality.
I guess you could ask the seller what they base their claim on, but my gut feeling is that is probably not an early Omega. There is a list (incomplete?) of Omega serial numbers here.
http://www.pocketwatchrepair.com/histories/omega.html
Louis Brandt & Frere were the original company behind the Omega brand.
There is also a list of some of the trade marks of Omega Watch Co. SA / Louis Brandt & Frere
here.
https://www.mikrolisk.de/show.php?site=280&suchwort=Omega&searchWhere=all#sucheMarker
However to be a genuine Omega watch, it would almost certainly have the Omega brand on it. None of their other brand names are "Genuine Omega" either (but slightly closer connected to the Omega brand  than some of the more obvious fakes out there).
Be aware that some sellers will use association (like saying a Sicura pin lever is a Sicura by Brietling) to claim a watch has a particular pedigree, when that is not accurate. Sicura bought the Breitling brand when Breitling went out of business, so a more accurate statement might be Breitling by Sicura, but either way, Sicura watches are not the same thing as Breitling watches, any more than an Omega with an ETA movement in it is a Swatch.
Edited by AndyHull
That's a Dennison case with the specially-fitted bow.  Really good case.  But although Omega has used Dennison cases before, I have to agree with the gentlemen before me: we see no symbol or name on the dial, no symbol or name evident on the movement, no serial number in sight, and no other indications.  If I were going to buy it, that seller would need to provide quite a bit of proof on this one if he wanted to convince me it was an Omega. I don't know where they hid the serial on this one (if it has one) but if under-dial photos or under-balance-cock photos were available, I'd ask to see them if the seller were asking Omega-level prices.
That said, if the seller is being extremely reasonable, I'd be tempted to buy it just for the case.  Those Dennison cases are nice.
Edited by KarlvonKoln
Agreed. There is a slight chance it is Omega, since some importers (important Jewellers for example) would insist on purchasing sterile dial watches. Also dials do get replaced after the fact, so it may be a replacement dial. However there would almost certainly be some makers mark some where on the watch, perhaps behind the dial, maybe behind the balance, or on the edge of the movement.
The case is quite nice, but if you buy it for the case only, that obviously should be reflected in the price you are willing to pay.
Although the case is Denison, I would kind of expect that too to be stamped with an Omega mark,
Something similar to this perhaps.
Edited by AndyHull
3 hours ago, RichardHarris123 said:
It went for £80, way to much I think
I would say so. If you look in the ebay sold listings for Omega pocket watches, under £80 there are currently 82 items, a large number of which look genuine, so if you are looking for a genuine Omega PW in that price bracket, take your time, and find something with less questionable provenance.
Edited by AndyHull
For what its worth, if you look up Omega and/or Brandt on bidfun, you will see quite a number of different calibers, but none seem an exact match for the one above.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk
Enter the keyword omega  (or brandt).
The serial numbers generally appear on both the dial side, and/or on at least one of the bridges on the balance side.
There are also Omega trade marks on most of the examples and in some cases an Ω on the balance cock.
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
