Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.Â
Do I detect a worn/scuff ring on the inside of the case back. If so then at some stage in its life the rotor have been rubbing on the inside of the case. Â
Hi everyone, i'm currently having a problem in algnment of the 7s26a hairpsring, it causing +13 rate when it comes to crown down possition. What should i do, what would be the technique for having it good. Hope to know any idea of how to do it right. Thanks.Â
🤔 the crystal doesn't have to fit onto a detachable bezel, it can be pressed into the front of the case. Very curious as to why there is a threaded ring inside though. I do have a record www that i could pull the movement out of but I'm away in just over an hour.
