Hi, very new to watch repairs s bear with me 🙂
I bought this Normana watch and despite not paying much at all, I love it - however, the step seems to have snapped half way down. Can anyone tell me where I can source a replacement and what I would actually search for - i.e. are there generic stems or will struggle to find one?
Thanks in advance!
Tony
Hi and welcome to the forum,  A nice clean watch and style, see why you like it.  First thing to to is remove the back and identify the maker and its caliber number as without this it will be gard going finding a stem.  Wirh the back off have a look under the balance wheel for a logo and a number or on any of the plates. They are sometimes under the dial. Once having determined the make etc If you are in the UK , Cousins UK or in the stares Jules Borel or Esslinger.com    Jules Borel have a very useful database which allows you to look up parts on particular calibers.     If you are unsure of the maker/caliber take pictures of them and re post. Many members are here to help you.
That's helpful, I'll get the back off when my tools arrive today - in the meantime, do these images help and as it snapped off, will the watch need dismantling to remove the broken bit? Thanks....
Looks like barrel bridge and the barrel is to come out to gain access to the remaining bit.
Can you show a clear close up of the broken stem thats attached to the crown.
Hairspring too seem outside the regulator slot.
Regs
Regs
There you go....hope that helps?
Certainly the mov.t does not need to be "dismantled" to remove it from the case. That is a front loader case, and your is the most frequently asked question by beginners - you can search using the box top right. In short, the crystal, or bezel is removed, then is removed from the front.
 As said its a front loader, you would find a seam around the bezel, crack the bezel open to uncase the movement.
  Is that a portion of the stem still attached to the crown? it might just unscrew , alum disolves steel in case a piece of the crown doesn't want to come out of the crown.
 So if you plan to attack from the dial side, remove the hands, dial plate to expose the keyless.
There is also an aproach from the barrel side,   release the barrel power through the click, remove ratchet wheel and barrel bridge then barrel should just fall out underneath which is the keyless mech.
Take plenty of pix as you dismantle, help with reassembly.
Good luck.
Good luck.
Big job for a first attempt then? 😕
You can watch the entire disassembly process in walkthroughs by WRT members and Mark lovic.
We,ll work with you step by step too.
This movement looks too good for a practice though.
Regrds
Not really. Removing and refitting bands, casebacks, bezels, crystals, stems, mov.t, etc - that is uncasing / casing work etc. is something that beginners must be able to do without issue before going to work on mov.ts.
It is generally not difficult, but can be frustrating and damaging to the watch when attempted without the proper tools and the full understanding of what is what and how it's done.
Regrds
Thanks for your advice....got as far as getting movement out, but how do I remove the snapped but of the stem still inside. I have loosed the small screw that keeps the stem in place, but its not budging - I thought it might have dropped out - no such luck!
Tony
Remove hands and dial, push out stem from dial (keyless) side.
See images below - I'm not sure how to 'push' the stem out....there doesn't seem to be anywhere to push from. Additionally, I am not even sure I can see it....
Thanks again,
Tony
I seem to have extracted the broken stem. A little more fiddley than I'd hoped for my first foray into watch repairs. All I've got to do is put it back together. Is there any maintenance I can/should do before hand?
Ya, put all the keyless( sliding pinion, winding pinion,  etc back on, insert tbe stem, instal the bridge/ selector fork back so you have the stem in place, test if the set mech works right, lastly  put the dial back on, this way you have all the set mech aligned  cuz sometimes it all gets misaligned which wont let you insert them stem in and if you have sized the new stem all thats left to do is lower the movement into  the case.
Good luck
Incidentally, and as you'll doubtless know, the movement is one of the bridge variants of the FEF 190, probably from around 1950, which may help with your search for any bits required.
Regards.
Regards.
Hi and thanks - but as I have literally only started my foray into watch repairs 4 days ago that's news to me - but yes, useful! 🙂
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
