What are these tools?
If you loosen the case back does that make any difference?
Yes that is where I got it from not bad quality, more impressed than I thought I would be.
This dimension now needs to be converted to a ligne measurement. -
Thanks, I think the answer to the triple prong problem is going to be peg wood with a hollowed out middle to press all three legs in and turn. Although I think me finding the spring is going to be a tall order, perhaps one from the bag of assorted springs I bought will fit. I’m guessing the springs are not magnetic too? As to the double prong problem. I guess I will try with a bit more vigour. Thanks for the advice. Rob
