Hello. I hope someone can help me shed some light on this. My watch below was working fine until a few days ago. Now when I wind the watch (Move the winder in the below picture clockwise while its pushed in) it just keeps winding without reaching a point where it doesn't move anymore. The second hand does not move and it seems the watch is not ticking. The thing is, when I give the winder just a little (very slight) turn counter clock wise wise having it in the open position (as see in the below picture) the second hand start turning and it seems like the watch starts running. Can someone help me understand what can be going on here under the hood. Thank you.
It could be a few things: a mechanical default somewhere in the keyless works (the linkages and transmission which allow the stem to engage its setting-mode or its winding-mode) or you may have a broken mainspring.
May I ask: how long will it stay running when you pull out the stem and turn it slightly, as you describe?
If you   "hear the click when trying to wind "    but watch wont wind, you have a broken mainspring.
Favre leuba made some twin barrel movements, can you show a image of the movement?
Regs
Hi. Some answers to the above questions. If I have the winder out and give it a very slight pressure counter clock wise, the second hand moved for 3 minutes without stopping before I let go of the pressure.  I'm sure it would have gone longer if I kept the pressure. In terms of the watch movement I've attached the picture. Thank you for your help with this. I am hoping there is a do it yourself fix (I'm not holding my breath) but if not  your help to get a sense of what's going on would let me know what it would take to fix it. Also, if someone can let me know how to find out the specific model/year of the watch that would be very helpful. I suppose you can guess I'm not a expert at this. Thank you.
39 minutes ago, WA123231 said:
do it yourself fix
There is a do it yourself fix.  Disassemble the watch, open the mainspring barrel.  Remove the mainspring.  Measure it.  Order a replacement.  Install the new mainspring into the barrel.  Reassemble the watch.  Wind and watch.
Having said that, if this is the first time you have opened a watch, I suggest that you buy some tools, take Mark's course, buy some junk watches on ebay.  Complete a few projects.  THEN, work on your watch.
I assume that your problem is a broken mainspring.
I see a logo on the plate in your picture, but the resolution is too low to tell what it is.  Typically, the logo and cal are printed under or near the balance assembly.
This in way eliminates broken gear teeth therefor confirms a mainspring issue, either a broken mainspring or dislodged arbour catch-spring eye.
No power gets reserved to be transferred onto the train.
When you make it run as you do, you are supplying power through the canon pinion.
That was going to be my answer it sounds like a broken mainspring.
I don't suppose you know the last time the watch was serviced?
You can change the mainspring but if the watches never been serviced it probably could use a good cleaning.
It is not, it has to be given to a watchmaker. Unfortunately, the repair cost will likely exceed the material value of the watch.
A Favre-Leuba made around 1950, with an FHF 70xx mov.t. The "exact" model may be difficult to determine even for an expert, companies changed small details all the time.
Hello again and thanks. So from what I am seeing people feel its a mainspring issue. With that in mind I have a few more questions.
I do want to get this fixed and I'm not sure the last the time watch was serviced. I'm assuming its been a while.
Can someone estimate (the watch was working fine until I must have done something wrong in terms of the winding) the cost of the watch as well as a estimate for a repair (best guess). At the end of the day though I do want to get it running and in good order because of what the watch means personally. That's probably why I should also not attempt to do this myself.
Is this something that should be taken to a specific type of place that specializes or can any repeatable watch repair location do it. Sorry I'm just not that familiar with this.
Where are you (on this blue marble)?
About 50 Euro, and starting at 150 respectively.
Hi so I'm back with a few more help requests. Yes, the main spring was broken at the tip around the arbor  and PS if it was salvageable that went out the window with some actions on my part. Also I lost the click spring for good measure. I also lost the arbor and some screws about 10-15 times along the way but at this point, I just need a main spring and click spring.
So based on what was mentioned here and some looking around, the watch is a Favre Leuba 'Sandow' Sub Sec Dial model (1940/1950 ish). Screen shots in some of the above posts.
I'm not looking at top notch time keeping, I just want to get it working reasonably well. I was quoted today about 200 CAD for the spring and there was not much interest in trying to get it for me as it stands so I may be on my own. I suppose the watch was looked at as a lost cause but its important to me.
My question is, is it possible to get a main spring for this watch and a click spring. Does the main spring have to be the exact spring for this watch or something similar if I just want it to run reasonably well. Is it possible to get a replacement click spring. I can't even fathom how they make things that small and delicate. I'm just not sure where or how to get these parts. I'm pretty sure with them the watch will run again.
Can I get some advice please. Are there sites on line that would deal with people in my situation and work with me on getting what I need? Would anyone be able to point me to stuff online that match my criterial in terms of parts or a similar watch where I can get the parts.
Thank you.
It's almost certain that you will be able to source the parts that you need but you're going to have to help us out with the movement ID. Are there any letters, numbers, or symbols stamped on the main plate underneath the balance?
Can you post a closer up photo of the movement than the one further back in this thread?
Deputy Barney Fife said: "There are three rules in this jail.  The first rule is to obey all rules..."
I wish you would have practiced on something less important to you like I suggested.
Click springs are easy.  Most shaped like shepherd's staff and with varying strengths.  Something like this.  If one is not exact, tweak it. I have several hundred...they come in handy!
You can measure your current spring if you have the equipment to do so accurately.  Then you can order a generic spring based on length, strength, end type, height.  There are experts on this forum who will chime in with the specifics--I am an amateur.
Did you lose the arbor forever?  Nothing evaporates.  They are ferromagnetic.  Get on your knees with a magnet and a flashlight...it is the right of passage.
Learning is an interesting process we all learn differently. Most of us will try to discourage newbies from working on things they shouldn't but there's a limit of how far we can push that. It's really hard to tell people sometimes that they should Not work on things they just don't want to accept.
This is where the painful expensive lessons come in where hopefully they will learn.
I think the best solution in this matter is just to figure out the caliber number and simply order the parts.
At Cousins or any other watch material house.
By the looks of it is is a FHF movement these have the model number behind the dial.
Or an AS it is either one of these and the parts you need are easily obtainable.
Hi. Thanks this is very helpful and yes I looked before I leapt but did learn allot over the last few weeks. Those click springs look like the one from my watch. Also thanks for the input on the spring. At the end of the day I found the arbor so I just need a replacement main spring and I myself lost the click spring by accident when I was putting back in the click.
Thanks. I just wanted to know if in general this was something that was within well reason for me to put some work into and get the parts.
They are incredibly easy to lose.  One trick is to put the movement in a baggie and poke a hole in the bag to release or insert the spring.  If it takes flight...it stays in the bag.
Hi. I hope this is a clearer picture. The thing is I'm not sure I'm in the best postion to take apart anymore from this stage if that is what is needed to get to that movement ID.
Actually. That is a really good idea. Thanks.
Thanks for the input. Its helpful.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
