Balance removal from captured index
Woolshire
I’ve noticed folks that are working on shock jewel watches rarely remove the balance from the cock, which makes perfect sense. But when working on an older watch, a technique needs to be implemented to fully remove the balance.
I’m curious how others do it. I pull the balance and cock off and gently turn it over. I then place a brass nail across the cock, under the balance. I hold that down firmly while I turn the index yÿto allow the balance to be removed. I also keep holding it until the hairspring stud is removed.
is this similar to how others do it?
I find the hairspring stud is awkward.  I put the cock+balance upside down on some pith wood, so I can get the screw driver horizontal. But often a balance wheel arm is right above where you're trying to work 😧.  That's why I often loosen the screw while the cock is still in the movement. Putting it back is harder.
To turn the regulator boot, I just hold the balance cock (inverted) flat on the desk with a finger. If it's curved, small, I use Rodico to hold it.
I considered trying to make something to hold the balance cock upside down, but there's so many different shapes and sizes it's not easy.
I'd like to hear if anyone has a better method
 Fixed stud holders generally came in two types,
One;,    stud friction fitted into the hole of the stud holder,
Two;     stud is secured in the hole by a screw.
 Other designs were manufactured too.
 I unscrew the stud with cock still on the mainplate, so there is no need to hold the cock down with brass or wooden stick,  the movement& movement holder hold the cock secure. this is safer and easier.
Usually faults in hairspring show when the oscilator is running, little faults however might go unnoticed specially if at or near the collet. You really don't have a good view of the coil unless the oscilator is out so it can be inspected under good magnification. I don't believe a audmars piguet get reassembled with a little fault in the coil.
Regs
This is a great topic. I have struggled with this issue.
i started using pith wood as a base with inverted cock, but it is too soft. you can accidentally press the cock into the pith wood. instead, I use a bench block.
I don't like removing hair springs, but for vintage non shock watches you have to in order to remove the cap jewel.
I have started removing the stud screw while on the plate, but that does not work in reverse.
 There is no need to remove the stud screw,  just loosening it enough to slide the stud out would do, I always make sure to tighten the screw all the way back in, it tends to unscrew and fall out in cleaning machine, specially in ultrasonic.
Use a wider blade driver on stud screw, twice to three times wider than screw slot, this would reduce chances of the blade leaving the slot in case of a little slipage.
Friction fitted studs are least versatile and riskiest to remove. I lift the cock and balance out, hold the stud in tweezers( tweezers supported by bench top)  and push the stud out. Nice to have a anvil to support the stud arm against.
Regs
Yes, I will admit I have totally messed up hairsprings trying to hold down with my finger and suddenly…fling! The balance cock flips away and the balance ends up, still attached and upside down under/around the cock…talk about immediate blood pressure issues?!?!
of course, this is only an issue on non-shock jewel watches with captured index
Here’s a photo of how I hold the balance cock while removing it via the index turn and balance stud screw….but another question: how in the heck do I get the jewels free? This is a little Omega (r13.5 calibre). Not screws but looks like the cover should turn to align the free spots, but it doesn’t want to turn. Another new one for me.
Edited by Woolshire
This video might help, have a look at 21:00 onward. Not sure if it's the same calibre but it looks like a similar retention method.
That holds it down nice and firmly, but it means your screwdriver is either at an angle or on the desk to undo the stud screw. That's why I hold it down either on a bench block, or some pith wood.
As shown in the video, put a screwdriver in the slot to get at the jewel.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
