I’ve noticed folks that are working on shock jewel watches rarely remove the balance from the cock, which makes perfect sense. But when working on an older watch, a technique needs to be implemented to fully remove the balance.
I’m curious how others do it. I pull the balance and cock off and gently turn it over. I then place a brass nail across the cock, under the balance. I hold that down firmly while I turn the index yÿto allow the balance to be removed. I also keep holding it until the hairspring stud is removed.
is this similar to how others do it?
I find the hairspring stud is awkward.  I put the cock+balance upside down on some pith wood, so I can get the screw driver horizontal. But often a balance wheel arm is right above where you're trying to work 😧.  That's why I often loosen the screw while the cock is still in the movement. Putting it back is harder.
To turn the regulator boot, I just hold the balance cock (inverted) flat on the desk with a finger. If it's curved, small, I use Rodico to hold it.
I considered trying to make something to hold the balance cock upside down, but there's so many different shapes and sizes it's not easy.
I'd like to hear if anyone has a better method
 Fixed stud holders generally came in two types,
One;,    stud friction fitted into the hole of the stud holder,
Two;     stud is secured in the hole by a screw.
 Other designs were manufactured too.
 I unscrew the stud with cock still on the mainplate, so there is no need to hold the cock down with brass or wooden stick,  the movement& movement holder hold the cock secure. this is safer and easier.
Usually faults in hairspring show when the oscilator is running, little faults however might go unnoticed specially if at or near the collet. You really don't have a good view of the coil unless the oscilator is out so it can be inspected under good magnification. I don't believe a audmars piguet get reassembled with a little fault in the coil.
Regs
The hairspring/balancespring can be removed in either of the described methods, its just a matter of choice and which method you prefer. The criteria in either method is to be careful because as many have found out the spring is easily damaged
This is a great topic. I have struggled with this issue.
i started using pith wood as a base with inverted cock, but it is too soft. you can accidentally press the cock into the pith wood. instead, I use a bench block.
I don't like removing hair springs, but for vintage non shock watches you have to in order to remove the cap jewel.
I have started removing the stud screw while on the plate, but that does not work in reverse.
 There is no need to remove the stud screw,  just loosening it enough to slide the stud out would do, I always make sure to tighten the screw all the way back in, it tends to unscrew and fall out in cleaning machine, specially in ultrasonic.
Use a wider blade driver on stud screw, twice to three times wider than screw slot, this would reduce chances of the blade leaving the slot in case of a little slipage.
Friction fitted studs are least versatile and riskiest to remove. I lift the cock and balance out, hold the stud in tweezers( tweezers supported by bench top)  and push the stud out. Nice to have a anvil to support the stud arm against.
Regs
Yes, I will admit I have totally messed up hairsprings trying to hold down with my finger and suddenly…fling! The balance cock flips away and the balance ends up, still attached and upside down under/around the cock…talk about immediate blood pressure issues?!?!
of course, this is only an issue on non-shock jewel watches with captured index
Here’s a photo of how I hold the balance cock while removing it via the index turn and balance stud screw….but another question: how in the heck do I get the jewels free? This is a little Omega (r13.5 calibre). Not screws but looks like the cover should turn to align the free spots, but it doesn’t want to turn. Another new one for me.
Edited by Woolshire
This video might help, have a look at 21:00 onward. Not sure if it's the same calibre but it looks like a similar retention method.
That holds it down nice and firmly, but it means your screwdriver is either at an angle or on the desk to undo the stud screw. That's why I hold it down either on a bench block, or some pith wood.
As shown in the video, put a screwdriver in the slot to get at the jewel.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
