Please help identify this pcoket watch
According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳 Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round Special forms plastic Armed
When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
Coffee is easy for me, strong and black. Hehe. Let us know how you get on with the crystal. -
Thanks guys you've been a great help to a beginner, every day's a school day 👍 I'm always crossing my fingers when I order a part as there's so many different numbers, I thought ordering a coffee was bad enough! 😆
This tells you how to fit the glass and they type of tool needed, but there are loads of this type of tool. https://blog.esslinger.com/how-to-press-a-tension-ring-fit-watch-crystal-into-place-with-a-watch-crystal-press/ When it come to buying the glass make sure you buy the one you need with the correct colour tension ring.
