Now This Is What I Call A Steak-Ing Set...
All this talk of staking sets gives me an appetite for one of my tasty steaks, and I thought I'd share the recipe with you. So here goes:
1. Start with a nice piece of steak - you don't need expensive fillet for this - a nice piece of sirloin will do, or even rump.
2. You'll need a cast iron griddle - one of those heavy, square Le Creuset-type pans with a ribbed cooking base.
3. Scatter sea salt on to a chopping board or a large plate and turn the steak in the salt until well covered all over.
4. I always cook with gas but, whatever medium you use, turn up the hob heat to maximum, until the pan is smokin'!
5. When the griddle is piping hot, on goes the salted steak - no oil, no butter - just steak.
6. Turn the steak over every 30 seconds and cook to your preference - 4 minutes, 6 minutes, etc., until done
7. Eat!
Tasty? Mm mm!
Have a good Bank Holiday weekend!
Will
Last night Sirloin steak for three as we had our Grandson overnight. Thought he might not like so fish fingers were put in reserve. However not only did he devoir his also helped me with some of mine. Used Wills recipe for the steak,large flat mushrooms & home made chips.
Thanks Will BUT the Diet 100% starts today.
    • Mike, you have summed it up following the KISS principle.   Tom
    • I think this is pretty typical when you have something that crosses many regional and international borders. @Neverenoughwatches yes Rich, that is the common way, learning from our teachers, however terms used in Yorkshire could easily be a lot different for tools, techniques or methods different from Scotland or Somerset. My (long winded) point is it all depends on where you first picked up the terms, if from books American watch terminology differs from English terminology and to a degree Swiss terminology. That also seems to extend to watchmaking schools. Confusing at first starting out but like anything else you get used to it. This will be why our long term members attach a glossary to new users introducing themselves as beginning their journey.    Tom
    • Personally I would just replace like for like.Or just polish the old crystal and refit.
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
