Hope someone can advise me please. I have recently acquired a watch with a compressor back. The back turns quite easily with a ball but I can’t remove it. I have tried numerous different ways of easing it off but no joy. Has anyone had any experience of removing please. There must be a technique that I’m not aware off. Any help greatly appreciated.987AE875-BDE0-4577-9291-8C2EEE8ACC7F.jpeg.df4d996a7d4867abd8d2fafa549ed193.jpeg
Have you tried a case knife. Have a careful look around the edge of the back and you should see where blade will fit in then pry it off.
A ball is used to unscrew a back. Your watch is not a screw on back.
I think Brevet is then French word for patient. Is there a makers name on the dial side. I agree with OH it very much looks like a friction fitted case back.
The Compressor and Super Compressor cases were made by EPSA. Super Compressors use either a screw on case back or a bayonet (I think for Enicar), but Compressors are a snap back. That being said they can be fiendishly tight and quite challenging for a standard case knife but it can be done. They should have 2 O ring seals as far as I can remember, if your case back turns quite easily then that would suggest that they may be missing.
Thank you all for the responses. It turns freely with a ball and there is plenty of room to get a knife in but it will not budge. I thought it may be a bayonet as well and have tried it at every position with a suction tool but again no joy. It’s very loose but just will not part. I’m stumped.
  • 1 year later...
Hi,
Recently I got a compressor case where I experience the same issue. The case back rotates but I cannot take it out. The caseback is loose but something is securing it.
4 hours ago, Henrique said:
Hi,
Pictures?
Not at home...I will get back in 2 months :(.  I just posting the pictures from ebay. The caseback is of screwback and rotates, but cannot remove it yet
You might want to have a look at this article to make sure that you correctly identify what you have got.
The original EPSA Compressor and Compressor II cases were snap on backs, while the Super Compressor was mostly screw on, with a few bayonet fit backs.
The lack of any notches in the back strongly suggests that you have a Compressor or Compressor II which is a snap back. The fact that it rotates suggests that the rubber gaskets are actually missing or have been replaced with gaskets that are too small.
    • My profile photo is age 20, last century, but I still look exactly the same so I'm not sure it counts ¯\_(ツ)_/¯
    • Hello everyone my name is Tom and I and I am new to the forum and new to the hobby. I have always had an interest in mechanical watches and finally decided to pursue it. I’m going thru online trading and have purchased the basic tools to set up a work area. I’m really looking forward to learning and thank you in advance for all of your knowledge!
    • This conversation is becoming a very confusing. The etachron system is a very nice system for manufacturing watches. As you know it consists of two components the stud and the regulator pins. Beautiful thing of this system is you can open up your regulator pins center the hairspring and as you close the pins they will close equally on both sides providing you centered it in the first place. It's not like you're going to become closer to one side or the other as the definition of the regulator pins is a bit confusing it's not exactly a slot sort of. I'm thinking maybe a little eight reading will be helpful for you. Then the file name was changed by me at the US patent but the wording of Seiko may or may not actually be attached to it soared up? I just did that so I can find it in my files. Normally patents are in people's name if they work for a company the company name will be there you'll notice the person lives in Japan which is interesting as the name would imply that this is a Swiss product. Somewhere I think I have the patents for the stud and I believe that is Swiss like a lot of things their Japanese and Swiss and then the Japanese let the Swiss name stand as it seems you more popular in case as you read up on the patents of the regulator pins or pin will see and it should explain exactly how and why it works also why it's important to always close at an open in specific directions because the pins actually have a shaped to them it's very hard to see the shape as it's very tiny.   As a reminder with this system it's mass-produced. I wouldn't be at all surprised if they use cameras and computers to do all of the adjustments.  The meaning of this is that the majority of watches will function as there supposed to and do what they're supposed to do the system will allow us for some minor in tolerance and has more than likely as I said no human hand is ever touched those watches that's the way they left the factory and they work fine. US2007091729A1 seiko etachron.pdf
