Hi All - New Member
Stretch
Hi all,
My name is Simon and i've loved and owned watches of all kinds from a child.  in the first lockdown i decided to take my interest to a new level and started repairing and refurbishing watches on an amateur level with the tools i have been steadily aquiring.  soon to take that leap into servicing some of my manual watches, once i can justify investing in the expensive oils and greases. I'll have to see what Santa brings this year........
Looking forward to chatting about and sharing watch knowledge with like minded people.
Hi and welcome Simon,
Like you I also have had a long interest in clocks and watches, started to strip and rebuild cheep watches from eBay at the start of lockdown.
As I had nothing at all I started by getting the usual budget kit, big mistake, nearly all have been replaced by now, so have finished up spending way more than getting the right gear to start with.
The oils last forever, so as I’ve started to clean and rebuild better watches so I’m having to get the better oils.
Get the right oils to start Simon, 2ml will last you ages and you’ll only finish up getting them anyway as you progress.
Good luck with your new hobby, try you local charity shops, I do repairs free of charge just so I can gain more experience, as an amateur I need all the experience I can get and if I can’t fix them the charity shop has lost nothing.
Graham
Cheers Graham and thanks for the heads up on the oils.
I did watch a you tube video which said to start with 2ml of mobius 9010/2, 20ml of mobius D-5 and 20ml of Mobius 8301 grease.  Should be able to get these from cousens for £58.
I'm always having a glance in charity shops whilst out and about, but i'm finding there is less and less old watches to be found.  One shop told me they all go straight out to a dealer that they sell them to. but i have 3 manual wound watches to keep me going for a while, which are in need of a service, which justifies the outlay for the oils.
my repairs all started when i'd had enough of paying £50 for Goldsmiths to change the battery in my wifes TAG 2000 series diver watch, then the Bezel rachet spring broke and TAG wanted well over £100 to fix.  Managed to get that part from USA delivered for $30 all in and did it myself and put a slide show on you tube to help others avoid having to pay out a fortune.
Also allows you to enjoy these expensive watches a lot more (£900.00 in 1999) knowing that you can replace the glass easily of it gets damaged, or replace the movement for £20 if it breaks.
  • 4 weeks later...
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
