Resources for screw restoration
JohnC
18 hours ago, nickelsilver said:
That's just my opinion though.
Not only your's 😉
Usually disregarded: most watch screws from the last century were nickel plated. Polishing will remove this protecting coat and make the screws ready to rust.
If possible, I sort e.g. bridge screws and place the worst ones in hidden places.
Frank
You are hardly going to clean up screws that are nickel plated for starters you should see past the plating to reveal what is underneath normally it will be brass if the screw has been buried.   I think here we have been discussing steel screws, I know I have.
Yes, that was certainly my intention. For example, I am currently working on a Russian Vostok 2809. The standard of finishing is fairly low and I doubt the screws are plated. The barrel arbor screw is badly bruised, and is quite unsightly. It would be nice to have a standard practice just to clean up steel screws, short of a full restoration and black polishing, as this level of finishing is not really necessary or appropriate on a movement like this.
    • I was pleased to pick up a selection of some tools on ebay (v cheap 🤣), and they've just arrived,  I've been looking for a crystal press for a while, and this one is ideal But in the selection is this thing - what is it for?  (it's about 3" long) Something to do with stem tubes?
    • You'll have to strip it back anyway.
    • I think I've heard that more than from just Alex. That doesn't make it right though, but I'm convinced i saw some literature diagram explaining why to do that. There must be good info here in the archives, I'll have to have a dig around.
    • That will mean dismantling the gear train, which with 5 pivots to align was a pain. Probably going to have to though. I'm convinced it's something to do with the great wheel.
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
