Lantern pinion
Willow
2 hours ago, RogerH said:
Check the file size. also the type
Just to be clear, what the topic I have linked before is about is to inform that the only attachments supported are images (JPG and PNG are the formats normally used), and documents in PDF.  Nothing else will work.
42 minutes ago, Willow said:
are these only for picture's, or can you use them for video's sorry about this new to all this file lark
Again: no video of any format can be attached. If you absolutely need to share a video, post on YT or other platform, then post the link.
Hmmm there's nothing glaringly obvious.....def need a video lol. how about a gif? it may be enough to show us what happens. If levers are jumping then it's worth checking teeth to make sure there's no damaged, bent or even dirt in between them that may be upsetting the movement.
what i can't understand the rest of the hours and half hours are fine will have a look at the wheels again thanks,
Hi thanks for the pics, As roger said nothing obvious, the lever is dropped cleanly in the count wheel.  Normally when they skip somthing is blocking the lever and it fails to lock properly allowing it to skip. But as yours only exibits the problem at 9  to 9.30 is a bit odd. Are all the other lockings clean and correct.  I should look for either somthing blocking the long  lever or kicking it up so a to release the count, check its operation for the full length and the interposing levers etc.
Yes all the other lockings are ok  thanks
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
