What to do about worn Timex crowns
Having gotten my Timex model 27 up and running, I've got another hitch both with this watch and two others that were straightforward clean/oil jobs:
The crowns have been worn almost smooth and unfortunately Timex crowns do not appear to be screwed onto the stems. I'm not sure how they were fitted to the stems and Google is not particularly helpful when it comes to removing and replacing them.
I've kicked around the idea of using either a needle file or a blade to cut new grooves, as this would keep me from having to make sure that the stem still seats properly with a replacement crown, but I'm not overly fond of this approach either.
NOS stems and donor watches are getting increasingly harder to find.
I've been toying with the idea of removing the old crown and cutting threads on the stem to fit an OEM crown.
One day I'll get down to doing it.
Right now I have an Accutron crown that sticks out by a little more that a millimeter. Obviously it doesn't belong to this case. And it's also a pressed on crown. Hmmm... 😏
Unfortunately, Timex crowns are press fit onto the stems, so there's really no way of cleanly removing and replacing them. I've toyed with the idea of pulling it off, milling out a regular crown and pressing a new one on, but i choose to just buy used Timexes with good crowns to service.
You can find NOS boxes of stems and crowns on eBay, but you have to find the exact one you need, and you need the service manual to find which one you need. I'm sure someone here has the manual in order to help you out.
    • Most all my 404 candidates are coming from swap meets and "antiques fairs". One more $4US plus battery and elbow grease. Unnamed digital on a decent ss bracelet. Gains 10 seconds a day so not that accurate...
    • I voted.for the 6.99 assuming £, which works out to $8.74US at the current exchange rate.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
